3.42-4.10s(LOL)
get outta here with ur missin gear **** pny lol jk man. So the lt1 wont pull as good of gas mileage as the ls1 guys huh??? that sucks but hey 23-25 with a v8 sports car is damn good in my book thanks for the info guys. Six speed and 410's in a moser 12 bolt comin soon hopefully.
I would say just a few MPG most.
When I did the 3.73s I could barely tell the diff. over 3.42s, yes it was alittle more snappy but not what i wanted and I was never satisfied. I know better this time around.
A4 is a diffrent story 4.10s will suck gas pretty good.
so if i did the 4.10s and got a eaton posi under my truck, waht would u say i could run?
the last time i went on a long trip i managed to pull off 29.5 mpg(432miles traveled to 1 tank) with the 3.42 gear. since that time i added Lt's,true duals,cai,tune,plugs,wires,4.10s so i would guess using 6th gear more often i most likely lost 1.5mpg WELL WORTH THE SACRIFICE!!!!
i love video w/audio get to hear THEM DUALS from the outside
#33
i am for sure low 13s will happen even at the altitude i am at. i did notice my car was running good but something just did not feel right found this today
fortunately i have 16 left overs well 15 now!
my buddy had a 94 z28 coupe,m6.mods were:
stock unopened Lt1 78k
Jet Hot Lts
3" Y-pipe cut-out
k&n cai,small pooper scooper underneath
52mm tb
added a vented opti and dowel pin
new timing chain
autozone clutch (LOL lifetime warranty)
madtuner cheap tune(100.00)
3.73s
nitto DRs 245/50/16
ripper shifter
ran 13.3s 1.9 60' NA and 11.3 on a 150 shot,got greedy and put 175 pills in there(against my advise!) stock fuel pump Motor went
Jet Hot Lts
3" Y-pipe cut-out
52mm tb
new timing chain
3.73s
nitto DRs 245/50/16
ripper shifter
#34
elite what is the DA there. I lived in phoenix for four years and it was like 125 degrees and i forget the altitude i know it aint low i wanna say 2000 - 3000 feet. Now i am in florida tons of humidity but gainesville raceway is like sea level.
#36
To be honest,my silver car is my every day driver. The 4.10s make the car way more efficient,when you leave from a stop light the car is gone compared to the 3.42s.......I run on c6 285/35/19s and of course they tame the gear down a bit. My next track visit will be on stock size 245/50/16 DRs.
Generally you will spend 180.00 on the gear and 200.00-300.00 for the instal,so when you begin to look at the dollar to performance aspect it is the same as adding Longtubes and Y-pipe. you will not regret this mod!!!!
#37
how do i find out what the DA is i never checked that
#38
hows the mpg gallon though? i currently have an a4 with stock 2.73 gears and i do about 20-21 mpg with mixed driving. so im wondering with the six speed where im gonna be at. That mpg is also with very delicate driving. mostly freeway and about 10-12 miles a day city driving.
look up a DA calculator...usually altitute, dew point, barometric pressure, and temp are taken into effect. Your gonna have to find a weather site that will give you that info
#40
