OBD 1-2 connector swap
If you stick an OBDII computer in the car, you'll need to bring the PCM wire Blue 7 to the diagnostic connector (that's the OBDII data pin). What I did was to use the OBD1 ALDL pin "B" (Mode Select, I believe it's Blue 20) and move it to the Blue 7 location. You'd stick that in to Pin 2 on the OBDII connector. You'll need to disable codes for crank sensor and rear O2 sensors though.
I converted my 94Z to OBDII for a time, went back to OBD1 eventually.
2- Serial Data Wire(Tune/Diagnostic Wire)
4,5- Grounds
16- Constant Power off of Battery
I have an OBD2 PCM & Engine, and had to wire the Connector just like that to get it to work, and it works without a problem.
The wiring was even inplace for the #2, just was never used cause I didn't have an OBDII PCM & Engine.
