Car has keless entry- can I make the lights flash or horn beep?
Old 10-25-2008 | 10:51 AM
jedimaster71472's Avatar
Default Car has keless entry- can I make the lights flash or horn beep?
My 97 has keyless entry, but not the alarm module. Is there a way to either add the module (and then get the fob with alarm button), or make the parking lights flash or horn beep when I lock/unlock the car?
Thanks in advance.
Old 10-25-2008 | 12:28 PM
HoLLo's Avatar
Yeah, as long as an alarm was wired into it. I don't think you would NEED a new remote, because the alarm button on the remote is only for "PANIC", but it would be good to have. Check ebay for those, it's where I got mine.
Old 10-25-2008 | 12:42 PM
Formula350's Avatar
Factory key less won't do it though.
Old 10-25-2008 | 03:48 PM
You mean it won't flash or beep the horn?
Old 10-25-2008 | 06:03 PM
integraxtc's Avatar
correct^^^
Old 10-25-2008 | 06:16 PM
95Yardbird's Avatar
Do i need a certain key fab? My car has keyless entry but i didn't get any fabs from the previous owner.
Old 10-25-2008 | 06:48 PM
Formula350's Avatar
Has nothing to do with the key fob, it's the factory system that doesn't do it. It's just not that style. I'm sure the 98+ do it, but I'm not sure if that system can be swapped into a 93-97. You're welcome to try, and I'd love to hear how it goes!
Old 10-25-2008 | 08:33 PM
Originally Posted by integraxtc
correct^^^
Gotcha.
Old 10-25-2008 | 08:43 PM
Kmaroman's Avatar
how can u find out if your car has keyless entry. Is there an option code i need to look for
Old 10-25-2008 | 08:50 PM
Formula350's Avatar
The other thread answered it, and it's RPO AU0.
Old 10-25-2008 | 08:59 PM
ZFan88's Avatar
And if you don't have the fob you can get one off ebay for like 30 bucks and program it yourself in 10 seconds, it's that simple
Old 10-25-2008 | 10:04 PM
harvickgm's Avatar
when i had my aftermarket one installed i asked the guy could he hook it up to the fog lights and the factory horn, and he did it with out any problem...
Old 10-25-2008 | 10:46 PM
Zralou's Avatar
I have the keyless option on my '94 formula, when I first got the car it had an alarm that operated the doors, and flashed the lights.
Unfortunately, it only works at temperatures below 45*, don't ask me why?, i've no idea, but over 45* it will arm the alarm, but won't operate the door locks or flash the lights, below 45* it works like a charm....
I just bought a regular factory button off of e-bay to work the door locks.
Sara Lou
Old 10-26-2008 | 10:33 AM
HoLLo's Avatar
Ummm.. my car honks twice when I lock my car. Flash my fogs, brakes, corner lights, and interior lights when I lock it also. Factory alarm module.
Old 10-26-2008 | 11:25 AM
Is it the factory alarm?
Old 10-26-2008 | 01:56 PM
Formula350's Avatar
Nope
HoLLo, you might have exactly what I was talking about with the 98+ Since your's is a 97!
Quick Reply: Car has keless entry- can I make the lights flash or horn beep?
