turbo 400 on lt1 what do i need???
i have a drag car camaro 94 lt1 and the 4l60e went bad this is the second one ive gone through in two years so im jus gonna go with a turbo 400 since there way stronger wut do i need to do for this to work. the trans came out of my dads 84 camaro and he also has the custom driveshaft that he used when he had this trans in his car, i beleive it will work on mine 82-02 are all the same i think. and obviously i need s turbo stall my 4l60 stall will not work, but what about all the computer stuff will it still work without electronic trans and do i need a diff trans crossmember. please help me out guys. thanks
thanks thats what i was thinking too. please more people join in here, let me know for sure b/c this will be a lot cheaper for me than buying another 4l60e or havin this one rebuilt. and how much hp can a stock turbo 400 handle??
bmr has a crossmember with the torque arm mount all in one. i have it in my 95z and works great, then custom drive shaft, new converter, new shifter i think not sure if the stock one will work. thats all i can think of
No you don't need a tune. The car will idle fine. You want proof? look in my sig. No tuning whatsoever all I did was unplug the connector from the 60E and zip tie aside. Now I do have an Ed Wright tune in the PCM but it was done when the stock 60E was in it before I ever even thought about a TH400.
I do have a RMVB so my only hookups are the tranny fluid lines, the linkage, VSS (my Rossler came with a VSS installed, I just plugged it in) and the transmission temp guage. The TH400 works very well behind the LT1 in a 4th gen. I love mine.
I think the cross member / tranny support is from a Manual Trany camaro and a guy here in Orlando gave me one for my TH400, worked great, but think I had to use spacers. Man it has been a long time since I did this.
Trust me a built TH400 is the way to go, put a trans brake on it and hold on!!
I also built this car to allow a big block with out any mods, Tranny, driveshaft, supports galore, and Moser 9 bolt spooled, 33 spline.
LOL If I was a "Dick" you would definately know it.
No you do not have to tune it but if the VSS is not close it WILL tend to freak out while you are coming to a stop from time to time witn no reason.
BTW IF I want proff I will go drive one of the many we have converted
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
There is a guy here local that rebuilds 4t65 and 4l60e. He is a sponsor on regalgs.org. His name is dave and his company is called triple edge performance. He can build a 4l60e to handle low 10's... If you are not planning on goin faster than this, I would check him out. If your shootin for 9's then yea the 400 is the best way to go.
BTW IF I want proff I will go drive one of the many we have converted![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Speed
Sensor.
Clear enough?
Maybe you should do some research so you are not so damn sensitive? Maybe you should take some lessons at getting your *** raped?
NOW I am being a Dick get over it LOL!
BTW My transmission NEVER died, converter did, and I put one hell of alot more power through it then most!
I just called up JEGS and got the tech to suggest one.
You can go stock or all out race with tech specifications.
Spend a little or spend a lot, just think about what you might do in the future with the car.
Resident Racing Jerk
why would the vss freak out if it is unplugged? pcm sees the car as sitting still and not moving at all times. should idle just fine.
i have done 2 conversions myself, but both those cars were m6s. they idled just fine and had no issues whatsoever with the vss. (except the speedo didnt work)
