Can you rip all this stuff out?
can u just rip all this stuff out and just cap it? what do u need to keep? anything? i've been putting off ripping out emissions for awhile, just wanna make sure this is a good chart to go by...
REMOVE
- Secondary Air can go. Remove the pump, remove the fittings on the manifolds along with all piping and hoses and just cap/plug the manifold fittings. You will have an SES light for not having the pump hooked up.
- EGR can go. Remove the flex tube from the passenger side manifold and remove the valve on the back of the intake manifold. Cap the vacuum line(s) and you'll need block off plates for the back of the intake and that exhaust manifold spot. Again, you'll have an SES light for having this disconnected.
- Evap can go. remove the solenoid and vacuum tubes and cap as applicable. There is the issue of how far you want to go with removing it. There's the 3rd plastic line that runs with the two fuel lines and you'll have to vent it still. Either under the hood, in the fender or yank it all out back to the charcoal canister in the driver side quarter panel. Again, I think there will be a SES light for unhooking this.
KEEP
- Now, your left with the CCV and PCV which I personally would leave be but, your choice to leave it or stick breathers on the valve covers.
- The distributor ventilation is important for the opti obviously. I capped that on mine since I'm using a delteq unit and dont have the spark going through my opti anymore.
- Lastly, theres the HVAC which I would leave. Unless for some reason you have some other configuration I'm not familiar with.
You asked so, there's my answer. Oh, and the SES lights that may come on wont cause any problems with how it runs. Just your run of the mill idiot light telling you the pieces aren't working (duh, they're gone). Just get'em tuned out.
Intake Ducting- straight to the Engine, the only thing that should be coming off of it is the Line for the Vent if it's a Vented OPTI.
Intake Manifold- Just the Vacumn Lines for the Brake Booster, PCV System, EVAP, and the Vents.
Headers- Nothing, they shoud just flow Exhaust straight out.
Only one I would be iffy with is the PCV/CCV because it is necessary to my knowledge but, you can substitute valvecover breathers and remove the hoses which some people do.
REMOVE
KEEP
Confused about your lid/hose question... only hose I remember having on my LT1 intake ducting was the little blue 90* elbow connected to a small rubber hose that fed fresh air to the opti.
I was wondering while the motors out can I pull all this now? or wait to get it running? assuming its all the same as this one on the Camaro.. And does anyone have picture of all this stuff I would take out because I know very little about lt1's(have other ls1's).. just how to pull them out and stuff them in pretty much.
