Head cam lt1 not making NEAR estimated power.
Old 11-11-2008, 08:57 PM
  #61
lt1z28camaro's Avatar
I don't know if it makes a difference or not, but when I start it up cold, they're quiet, but once it gets to running temperatures they get alot more chattery..
When I am cruising in say 2nd gear and I give it half maybe a little more than half throttle, it will stay there for a second then if I give it more it will realize I'm trying to accelerate if that makes sense.. I never noticed this until today.. This could be either lack of spark or fuel right?
Old 11-11-2008, 09:02 PM
  #62
AChotrod's Avatar
Or the rockers are not adjusted right
Old 11-11-2008, 09:05 PM
  #63
AChotrod's Avatar
This is also from LE
"Make sure and adjust the rockers to 1/8 turn past zero lash."
We will get this sucker right!
Again check the plugs and wires. Watch all around the headers in the dark for arching.
Old 11-11-2008, 09:09 PM
  #64
AGREED! haha
Do you guys recommend on just adjusting them when it's off and turn motor over by hand? (I did that way, they were still loud, then I adjusted when running and they are STILL pretty chattery..)
Old 11-11-2008, 09:12 PM
  #65
Damn, I did 1/2 turn.. 1/8 seems like very little! But really, what do I have to lose, hp!? (like I can lose anymore!) Wires are all good, just by visual check during day.. I'll start it up at check for arcing in a couple minutes.
  #66
AChotrod's Avatar
Old 11-11-2008, 09:36 PM
  #67
No arcing, I'll be adjusting to 1/8 tomorrow.
Old 11-11-2008, 11:52 PM
  #68
buffman's Avatar
stock lifters 1/4 turn is more than enough. What kind of comp cams lifters are they? IIRC the Comp-R ones need very little preload. I do a dynamic setting with the car running. One rocker at at time.
Old 11-12-2008, 08:41 AM
  #69
ulakovic22's Avatar
Stock preload is 1 turn +/- a 1/4 turn. With that said, on my stock replacement lifters from comp I ran about a 1/4 turn. What does your sweep look like on the valve stem? I agree that you need to run your valves again and use the EVOIC method. It's the most fail safe way to do it. Also there is nothing wrong with a mail order tune on a H/C car, you just have to log your car with AutoTap/Datamaster/etc. so you can have the guy make adjustments. I sent my computer back to Ion 2 times and the tune was dead on. I went and had a dyno tune done and didn't gain anything, but driveability improved a little, not enough to justify the $400 tag though.
Old 11-12-2008, 10:56 AM
  #70
kinglt-1's Avatar
^Agreed!
Quick Reply: Head cam lt1 not making NEAR estimated power.
