Steering Linkage Removal Impossible!!!
Old Nov 14, 2008 | 11:58 AM
ThreeHonks's Avatar
Default Steering Linkage Removal Impossible!!!
ok im installing a set of LT headers and the last thing I need to do is remove my steering linkage. I understand that there are only two bolts that hold it together. I got the top bolt out easily and now the bottom one is giving me trouble. It looks like it is slighlty touching the rack and pinion so I can get a socket on it and I still have failed with even a wrench... can anyone walk me throguh this? Help!!!
Old Nov 14, 2008 | 01:22 PM
impaled's Avatar
breaker bar and maybe some PB blaster. either of those should help you out.
Old Nov 14, 2008 | 01:35 PM
ThreeHonks's Avatar
ive been spraying it with penetrating grease for a few days now lol and it still wont budge
Old Nov 14, 2008 | 01:37 PM
phirepower's Avatar
heat it up. They are a pain in the ***, but chances are you're being too gentle smack that bitch around a bit
Old Nov 14, 2008 | 01:49 PM
ThreeHonks's Avatar
Ill put a torch too it... i have been pretty gentle with it, i didnt want to be too hard on it since it is kinda an important part
Old Nov 14, 2008 | 01:50 PM
ThreeHonks's Avatar
BTW, does the steering linkage even NEED to come out for a header install on an fbody? I nvever took mine off when I put LT's on my mustang
Old Nov 14, 2008 | 02:52 PM
JB_97ws6TA's Avatar
Absolutely yes and I would remove spark plugs until you get the header situated in there then reinstall before you torque the header. I made that mistake thinking that I would be careful and I ended up cracking my spark plug and, as I am sure you are well aware of, they are a pain to swap out with LTs installed.
Old Nov 14, 2008 | 03:23 PM
ThreeHonks's Avatar
I already have my plugs removed, im just gonna get some TR-55s while im in there so I wont have to worry about it later. I just tried to grind a socket down to get the bolt on the linkage and snapped the socket lol
Old Nov 14, 2008 | 06:04 PM
LT1's Avatar
LT1
I didnt remove the steering linkage completely. I just removed the top bolt and moved it to the side.
Old Nov 14, 2008 | 06:55 PM
Fbody4Ever's Avatar
if the linkage is in a position where the bolt head isn't quite accessible..why not just turn the steering wheel to where you can get a socket on the thing? you don't need to be grinding tools or anything else.. Turn the wheel and realign the linkage, Put a socket on it, fashion a small breaker bar if you need it and loosen the bolt. Good luck.. I hate getting stuck on one bolt.
Old Nov 14, 2008 | 07:17 PM
riceburnerZ28's Avatar
when I installed my headers I think those bolts were a pita but i used a few extensions and a breaker bar then I used a pry bar .
Old Nov 14, 2008 | 07:52 PM
James Montigny's Avatar
Removed mine without much issue.
Then again, mine has been out a few times in the last few years for head, header and motor installs LOL
PB Blast and a a good prybar are your friends.
Turn it left or right to get the best angle of attack.
Old Nov 14, 2008 | 08:04 PM
wrd1972's Avatar
Use a big flat tip screw driver to SPREAD te lower fitting so it will slide up and off. Just pry the thing open a bit.
Old Nov 14, 2008 | 09:05 PM
chavez885's Avatar
Thats what i did.
Old Nov 14, 2008 | 09:15 PM
the_merv's Avatar
I never had a prob with mine, maybe yours has seen more weather..
I bought a 24" Extention that comes in handy for ALOT of things..lol
Old Nov 14, 2008 | 10:43 PM
Bad_tx_Z28's Avatar
not only did i have to remove mine, i had to grind the linkage down a bit and dent one of the primarys a little to get mine to fit.
Old Nov 14, 2008 | 10:55 PM
the_merv's Avatar
^^LS1 Linkage and Rack, works a whole hell of alot better..
Old Nov 14, 2008 | 11:49 PM
1badzee's Avatar
Its just one bolt isnt it? ::
Old Nov 14, 2008 | 11:52 PM
One at each end, holds the clamps tight.
You unbolt, then pry the bottom clamp up off the shaft it drives.
The top is then easy to remove. (or you can just flip it up work below it and flip it back down again)
Old Nov 15, 2008 | 09:30 AM
ThreeHonks's Avatar
thanks for all the help... i got the top bolt off no problem so this header install is waiting on a single bolt to come off lol I'm just gonna try to not be as gentle with it. I'll try to move the linkage up with a crowbar cause if I can get a socket on it, it will be cake. Its not rusted or anything either, it just not in a postition where I can get enough leverage on it with a wrench
