keyless entry problem...help
Old Nov 14, 2008 | 12:27 PM
Bad_tx_Z28's Avatar
Default keyless entry problem...help
ok guys, before i bought my new keyless entry remotes i tested the the keyless entry module by jumping the A and G ports on the DLC. The locked cycled and evey thing worked. I got my remotes in today, and i go to jump the A and G ports and nothing happens. What the hell?? So, do i need to reset the PCM before i the keyless entry module will go into pairing mode or what. Any help is greatly appreciated!!
Old Nov 14, 2008 | 12:54 PM
Bad_tx_Z28's Avatar
nevermind guys, the paperclip i was using didnt want to work. I finally got mad and used a piece of wire and it worked. The only problem now is the Lock button doesnt lock the doors. Every other button works fine. Any ideas?
Old Nov 14, 2008 | 10:31 PM
Bad_tx_Z28's Avatar
anyone?
Old Nov 14, 2008 | 10:38 PM
Bad Lt1 Camaro's Avatar
iv had this problem before, i reset the computer and went through the programing process again. It worked for me. Also check to see if the battery isnt dead lol
Old Nov 14, 2008 | 10:39 PM
Bad_tx_Z28's Avatar
the lock button didnt work for you either? nah my batt is good. Optima redtop.
Old Nov 14, 2008 | 10:51 PM
no it didnt work for either remote until i reprogramed it. since then i havnt had ne more problems. if that doesnt help i dont know any other solution. good luck
Old Nov 14, 2008 | 11:20 PM
Bad_tx_Z28's Avatar
thanks, i appreciate it!
