Getting ready to del all this to Speedinc!
Old Nov 24, 2008 | 05:13 PM
  #201
AChotrod's Avatar
Thanks!LOL!
Old Nov 24, 2008 | 05:43 PM
  #202
BADHAWK51's Avatar
Nice build looks and sounds great. Speed is a great shop to deal with they have always taking care of me. BTW I have seen 1mph gain with my cut outs open.
Old Nov 24, 2008 | 05:55 PM
  #203
AChotrod's Avatar
Thanks!!!
Thats why I had them throw one on!!!!!
Old Nov 24, 2008 | 09:18 PM
  #204
NightTrain66's Avatar
LS1TECH Sponsor
good results. It makes it easy when customers go the extra mile and get everything needed to make my heads/cam look good.
If the S60 (9 3/4 ring gear) has a big heavy poosi unit in it, we could lose 25 HP or so. If it has a light weight spool, maybe only lose 15 HP over stock.
Larry probably has a better idea about what kinda loss there is from the rear end swap but there is DEFINITELY some power to be gained with a cut out right before the rear end. 3" true duals would be even better but cost about $400 and have less ground clearance.
Lloyd
Old Nov 24, 2008 | 09:39 PM
  #205
Z-RATED94's Avatar
Originally Posted by AChotrod
Yep^^^
The MR G 5716 gaskets are .026 and I shaved my heads .030 for 11.4 1 comp.
New opti is in and heres the new numbers. With a cut out or True duals we can get more!! Pulls nice up to 6700 and check out the TQ curve! !!
Now THAT is sweet. Good job AC, Lloyd and SpeedInc.
Old Nov 24, 2008 | 09:42 PM
  #206
James Montigny's Avatar
Very nice
Old Nov 24, 2008 | 09:54 PM
  #207
AChotrod's Avatar
Thanks!! Those guys did great!!!
I hope I dont lose 25 with the S60. Well the cut out should help!
Old Nov 24, 2008 | 09:59 PM
  #208
LS1 SPEED's Avatar
I would say 20ish is a good guess Lloyd. We seen 14 rwhp loss when I went from a 3.42 to a 3.90 in my 02 Z06 before.
so figuring in the S60 with a 4.10 + the CM DS over the alum shaft removed will eat some power
then add the cutout which we could see 5-10+ HP
I think you would still be 390-400 after the S60 + cutout.
Last edited by LS1 SPEED; Nov 24, 2008 at 10:01 PM. Reason: because I need to proof read more
Old Nov 24, 2008 | 10:03 PM
  #209
LS1 SPEED's Avatar
you would never know by driving the car, so don't worry
Old Nov 24, 2008 | 10:07 PM
  #210
AChotrod's Avatar
Sounds good to me!
Old Nov 24, 2008 | 10:10 PM
  #211
strokin93z's Avatar
im ready for a launch video!!!
  #212
That's the key right there ....
You won't be the guy oiling down the track, you'll be the guy making
spectacular launches and pissing off everyone who is babysitting a 10bolt LOL
Your clutch is going to hate you
We don't race flowbenches, or dynos or postcounts LOL
Old Nov 24, 2008 | 10:13 PM
  #213
LS1 SPEED's Avatar
I'll make one tomorrow on the test drive since the roads are supposed to be dry
J/K..I will safe the clutch raping for Mike.
Old Nov 24, 2008 | 10:15 PM
  #214
Elliott's94Z's Avatar
^^^Lol!! That's awesome!
Old Nov 24, 2008 | 10:20 PM
  #215
lt1z28camaro's Avatar
Just curious as what clutch you're running?
  #216
AChotrod's Avatar
If the weather holds it will hit the track!!
Old Nov 24, 2008 | 10:21 PM
  #217
AChotrod's Avatar
"El Stocko"
Old Nov 24, 2008 | 10:22 PM
  #218
To satisfy board curiosity, would you be willing to run a few more dynos to compare
10bolt to S60 and before cutout to cutout open/closed?
Old Nov 24, 2008 | 10:24 PM
  #219
Damn, is it gonna hold that power? I miss the drivability of my stock clutch
Old Nov 24, 2008 | 10:28 PM
  #220
AChotrod's Avatar
LOL! I only intend to try it out at the track once then it will get a new one over the winter!
