Tranny install problem (A4) sigh..
(THIS PIC IS NOT FROM MY CAR. I FOUND IT ON GOOGLE AND CIRCLED WHERE IT'S TOO SHORT)
I have actually seen some Transmissions where the Pans are in different spots, and the Bolts on them are too. You may have to check that with the Tranny you pulled out, there probably is a slight difference, and this is the point where you are noticing it.
re-adjusted the cable.
To do this, remove locking clip where you adjust the cable then push or pull (whichever) and slide the cable to about 1/4 inch less than where it sits in "Park". Then put the locking clip back on and push the cable on to the shifter bracket till it snaps in.
This is not a 700R4 but the cable should sit similar to this before locking it.
http://shbox.com/trans/L2.jpg
More on adjusting the cable on this site
http://shbox.com/trans/A4_trans_linkage.html
