optispark...
Old Nov 22, 2008 | 10:12 PM
cammed93TA's Avatar
Default optispark...
sorry guys I search and didn't find anything...so hopefully someoen can help me here...
I just installed my opti...went to fire her up and all i get is cranking, and a gun fire sounding pop out my exhaust....
any info will help?
is it a timing issue?? or is the opti junk??? please let me know!!!
I should also tell you I have a vented opti on my car...
Old Nov 22, 2008 | 10:14 PM
Drumer919's Avatar
sounds like the timing is off.
Old Nov 22, 2008 | 10:15 PM
cammed93TA's Avatar
how do I adjust that???
Old Nov 22, 2008 | 10:21 PM
cammed93TA's Avatar
could I just have put the opti on wrong???
Old Nov 23, 2008 | 01:38 AM
the_merv's Avatar
Veteran: Air Force
Make sure the Dowell is in the right Slot.
Talking about the Opti here before anyone take that one and spins it..
Old Nov 23, 2008 | 08:27 AM
1995Transamconvert's Avatar
I had to replace all my spark plugs after my opti went out...it fouled all of them. Plugs are cheap..good luck
Old Nov 23, 2008 | 11:24 AM
BALLSS's Avatar
yes you most likely did
the dowel pin on cam needs to fit in the rectangle slot
Old Nov 23, 2008 | 11:31 AM
It will still go together if it's not in correctly. Take a black perm. marker and make marks on the timing cover and the new dist so it's easier to line up the dowel with the slot.
Old Nov 23, 2008 | 08:29 PM
cammed93TA's Avatar
thanks to everyone who helped out...I got it going also the opti cover wasn't tight enough had to tighten it...i really hate opti's ha ha...
By Brett Foote | 2026-06-04 05:00:17
