Blower install on a LT1
Old Nov 26, 2008 | 02:12 PM
BizZzatch350's Avatar
Moderator
Default Blower install on a LT1
So how bad is it? Kinda curious, whats the worst part? I'm thinking like a S trim for example. It lives where the air pump goes right, so that has to move. But what else would make it so terrible, I can't think of much.
Old Nov 26, 2008 | 02:17 PM
ss.slp.ls1's Avatar
I'm pretty sure the worst part is just doing the wiring/tubing. It's not that hard of an install.
Old Nov 26, 2008 | 02:42 PM
Pretyflywiteguy's Avatar
forge the internals before you go through the hassle of the install because it won't be long till you have to rip everything out to rebuild.
unless of course you already have forged internals then it what I said is irrelevant
Old Nov 26, 2008 | 02:55 PM
Moderator
I don't really care about breaking the motor.
Old Nov 26, 2008 | 03:11 PM
ss.slp.ls1's Avatar
Just run the right amount of boost and you'll be fine.
Old Nov 26, 2008 | 05:23 PM
wickedbusa's Avatar
I don't know how bad the install is, but I'm running a T-Trim with an aftercooler and it's a nightmare under my hood.
Old Nov 26, 2008 | 05:30 PM
Moderator
You're right, I have seen the after cooler set ups they take up some real estate. I was thinking a non after cooled S trim with an alky kit, simple set up. Mainly just bored and want a project always thought it would be cool to have a blower. Plus I have seen some kits for around $2K.
Old Nov 26, 2008 | 05:35 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Honestly I would go with ATI but everyone has their preference. The install is not bad but I would start by replacing the balancer with an ATI Superdamper so you can get a key on the crank. I had my balancer spin on the crank and it almost came off once. Take the nose off to run the intercooler tubing and that goes OK....there is always some trimming on the hoses. Check my build in the link in the sig and that may give you some ideas.
Good luck,
Jon
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Nov 26, 2008 | 05:40 PM
wickedbusa's Avatar
If you want to see pics of my setup when it was installed, go to http://www.donleeauto.com/ and click on customer cars. Go to page 2 and click on the 30th SS. There are pics under my hood and with the nose off for the intercooler install.
Old Nov 26, 2008 | 06:39 PM
Speed Density's Avatar
hashtagBMW
Thats what I like to hear Neil!
As long as you have some time Im sure it woulndt be a hard install and dont run that aftercooler, those are junk. But you will need something to keep IAT's down especialy in TX.
Old Nov 27, 2008 | 08:26 AM
MySuperSportCamaro's Avatar
Here's mine:
http://www.youtube.com/watch?v=lyycHkEnHYA
worst part in my opinion is that damn elbow that goes to the blower itself, I did with engine in he car so it was very hard to stick my hands beside the headers, no room what so ever. If you do it do it with the engine out and drop the whole thing in in one shot. No big deal really it's a lot of fun and a lot of WHINING.
Old Nov 27, 2008 | 08:34 AM
meanredZ's Avatar
That is the exact setup I'm getting ready to do. I haven't been able to make up my mind on which way I want to go with my car but that setup sounds fun. I found a guy selling a kit for pretty cheap on a local board too. If I wouldn't do that I would probably just do a cam and spray or something.
