Help with ALDL cable
Old Nov 27, 2008 | 08:38 PM
Goat2NV's Avatar
Yeah we should be past that part. He's talking about were you select the com port {ie usb port} for the program to interact with the ALDL cable. I need a little more info from him to help him out.
Old Nov 28, 2008 | 01:15 AM
crookedbowtie's Avatar
Did you turn the key on the column to the run position. Had that problem with a scanner until I realized I'm an idiot. Don't know if the cables work the same and it is simple...just throwing it out.
Old Nov 28, 2008 | 03:37 AM
SS RRR's Avatar
Village Troll
Wink
Buncha computer geeks all up in here!
Old Nov 28, 2008 | 04:46 AM
dhdenney's Avatar
Originally Posted by Goat2NV
dhdenney, with Windows Vista you can make a program run using Windows XP format. I'm not sure if you can do it with all programs, but I've had to do that with a couple. If you click on the properties of the program, then click on the compatabilty folder and click Windows XP (service pack 2), you do it in there. Hope this helps you.
Oh if it were that simple. I've already tried that. And yes the com ports matched.
Old Nov 28, 2008 | 04:52 AM
dhdenney's Avatar
BTW, I was using a USB-serial adapter. Could this be my problem? I don't wanna buy the USB cable and it be useless.
Old Nov 28, 2008 | 06:25 AM
Goat2NV's Avatar
Nah, it shouldn't be the adapter unless you have the one that has numbers on it with little pins. If you do have that one and you've accidently moved those pins to a different position, you change the configuration of the adapter.
Old Nov 28, 2008 | 11:20 AM
dhdenney's Avatar
Elaborate. I'm only partially computer literate, lol.
Old Nov 28, 2008 | 07:13 PM
Goat2NV's Avatar
Well some of those adaptors are made to accomodate several configurations. Just because something uses a 9 pin serial port, doesn't mean that it uses all 9 pins or it may use those 9 pins in a different order, similar to a firing order. Hopefully that helps some.
Old Nov 28, 2008 | 08:13 PM
dhdenney's Avatar
That makes sense. Thanks!
