Help with ALDL cable
I have now uninstalled everything and i'm ready to start fresh. can anyone with expirence with it help me out?
Just saw the post where you said that nothing ever works for you using usb. If you do have the serial port, you could find a serial to usb turn around, possible at radio shack or a computer store.
click on properties
click the compatibility tab
check "run this in compatibility mode for" and select XP service pack 2
check "run this program as an admin"
and you should be good to go.
