please help me!friends head is swelling
#41
#1 mod is always the driver-mod.
If you guys are going from a dig, get some drag-radials and watch him spinning his tires trying to catch up to you.
If you're going from a roll, get a nitrous-system. Most bang for the buck, hands down. Just be sure he doesn't know you're installing it. It would ruin the surprise for him.
#43
Can't reiterate enough, DO NOT GO DRY! Its great on LS1 cars cause they can read the shot and readjust for fuel, on the LT1 you need a boost a pump, completely not worth the trouble. Dry is way more expensive than wet on a LT1, and its not a good way to go.
Check your fuel pressure before spraying it, make sure your pump is in a healthy working order.
again- DO NOT GO DRY- - we cannot stress this enough..
Actually throw a 125wet shot at it and jet her a little rich , you should be fine for pretty much ever..
#44
you don't need a boost a pump with dry shot just a nitrous pressure regulator
dry is not WAY more expensive, yes best case scenario you will want to upgrade your injectors
picked up my used dry kit for $125 with a bottle heater and got some 30# svo's for $140
never had a problem and didn't cost me hardly anything, I do perfer wet though
if you do go wet though I wouldn't recommend a plate kit, it's known to not equally distribute the fuel/n2o mix to all cylinders
#45
Don't expect much! without better valve springs, the stock ones are a joke, you would be amazed at how high these motors will rev with good valve spring. You can change them without removing the heads for around $300 beehive work great.
