Mids w/ a cam okay?
Old Dec 4, 2008 | 07:19 PM
96capricemgr's Avatar
Mids work for me too.
Old Dec 4, 2008 | 09:49 PM
supernaturalta's Avatar
Originally Posted by meanredZ
Hey guys, I am trying to mod my car without spending a whole bunch of money and have decided to go with a cc 503 cam and maybe hit it with a 75-100 shot. I'm trying to save as much money as I can and was wondering if I would be okay staying with the Mac mids and doing an ORY. I know I would make more power with longtubes but is it enough to really have to spend the extra cash? I will be changing to a magnaflow catback as well because flowmasters aren't very good, which most of my mods were on the car when i bought it so I can't complain too much. I'm definately going with a Yank stall because I don't want to cheap out on the car but I want to save as much money as possible. So what do you guys think, are longtubes a must or will I be fine?
I think with the mid-length headers and the possible nitrous shot, I'd go with something that has a good 10+ degress more duration on the exhaust side than the intake side, and a fairly large LSA, like about 114 degrees. You can do better than a CC503 for this application.
Old Dec 5, 2008 | 05:12 AM
The "wide LSA for nitrous" thing is missaplied here. No need to do it unless you are spraying a whole lot more, lkie 2.5 times as much. What people fail to consider is the usual 112lsa is already quite wide compared to optimal.
Old Dec 5, 2008 | 12:20 PM
blackz93's Avatar
Werd.
Old Dec 5, 2008 | 05:05 PM
Ooooook.....so why do most "shelf" grinds for the LT1 have a 112-114 degree LSA? Please, do enlighten us.
Old Dec 5, 2008 | 06:06 PM
http://www.babcox.com/editorial/ar/eb90252.htm
This is not new information the author states he did the testing in 1985 and it was frankly well known long before that, problem is real data has a hard time overcoming "conventional wisdom" .
Old Dec 5, 2008 | 06:09 PM
speed_demon24's Avatar
What kind of testing have you done to come to this conclusion?
Old Dec 5, 2008 | 07:37 PM
Wow, they made the LT1 (not the LT-1) back in 1985? Look, I'm aware of most SBC "shelf" grinds using 108-110 degrees LSA, so I was asking YOU if you knew why most LT1 "shelf" grinds used 112-114 degrees LSA?
Old Dec 5, 2008 | 07:43 PM
I don't have to do any testing. That's the beauty of being literate.
"You can get a good look at a t-bone if you stick your head up a bull's @$$, but wouldn't you rather take the butcher's word for it?"
In other words, people and companies who make cams would make the same "conventional wisdom" recommendations I made to "meanredZ" based on the testing they've done, which is very safe to say, WAY more than you or anyone else here has done.
So my question to you "naysayers" is, what testing HAVE YOU DONE to dispell "conventional wisdom" on the LT1 engine?
Old Dec 5, 2008 | 07:59 PM
What about the LT1 would cause it to want a substantially different cam than a gen 1 smallblock??
The off the shelf LT1 stuff is wide for a few reasons, people overcam and then complain about manners, emissions, ASSUMPTIONS that the computer couldn't handle overlap are the biggest reasons.
Since you seem to believe please show us data that suggests the 112-114LSA are benificial.
Old Dec 5, 2008 | 08:23 PM
That's what I'm asking. What's really different about it that warrants the "major" cam grinders out there to use 4 degrees more LSA on the LT1? I was curious. There had to be a reason, and I'd agree A LOT of people out there "over cam" their engines. That's why one of the fastest cam only LT1s ran a "puny" Crane 227 (which by the way, has a 112 degree LSA).
Old Dec 5, 2008 | 08:48 PM
  #32
see my above post emissions and bad assumptions about what the computer can handle.
Old Dec 5, 2008 | 09:26 PM
  #33
I did. You can probably add to that, people also want their power brake equipped car to be able to stop. Optimum power may be had with some "lower" LSAs, and granted, a guy could just bump idle speed up some and voila, now you have enough vacuum for your brakes along with a smoother idle. I don't think there's many folks out there who likes their "street machine" idling at 1500rpm; the game completely changes when talking about dedicated race cars though. Even some of them are still better off with higher LSAs.
Old Dec 5, 2008 | 09:27 PM
  #34
My brakes work fine with an 800 rpm idle and tight LSA cam.
Old Dec 5, 2008 | 09:34 PM
  #35
Wow, no kidding? How much vacuum do you have at 800rpm?
.....and 96capricemgr, what would you recommend to the OP for a cam? I think we can agree that the CC503 isn't the "optimum" nitrous cam.
Old Dec 5, 2008 | 10:14 PM
  #36
blackz93's Avatar
Because they don't know any better!
When has a shelf grind made the most power in a given setup? NEVER, that's when!
Old Dec 5, 2008 | 10:57 PM
  #37
Never measured it but my brakes work fine. So far I've run the crane 227 cam, gm846, 224/230 107lsa bre cam , and my Ai cam so I have a pretty good idea how cams perform and drive in these cars. So as you can see I am speaking from personal experience, not what Ive read online or going with what the latest craze is.
Old Dec 5, 2008 | 11:08 PM
  #38
Javier97Z28's Avatar
My brakes work on my mid/high 10x LSA cam.
Could probably use a vacuum canister every once in a while when my idle drops too far, but I've yet to have a scare.
Old Dec 5, 2008 | 11:55 PM
  #39
Since when does having the most power out of a cam the highest priority? Oh yeah, that would be on the racetrack. How much time does most people's cars spend on the racetrack? Who really wants cam surge in a street car? Who wants the crappy gas mileage associated with high overlap cams? Oh yeah, gee whiz some people even have to deal with a small thing called emissions compliance. Yes, those little things that someone with a purpose built race car doesn't have to worry about.
I'm not sure if he posts here, but go to camaroz28.com and do a search for username "Frank95z". He's the example I used in my post about the Crane 227. He ran 11.40 with that cam on stock unported heads. Not only is that a "shelf" cam, it's a VERY mild shelf cam. He later moved on to a custom Joe Overton cam and went about .25 seconds faster, but he said his driveability suffered quite a bit just for that .25 seconds.
Old Dec 6, 2008 | 12:46 AM
  #40
That 25 mpg I get on the highway is just terrible isn't it. You really need to stop talking about stuff you have 0 personal experience with. Pretty much everything you are saying is false. And I had the crane 227 cam before and this cam beats that cam in pretty much every category including lowend torque.
