What Ignition Box
Old Dec 3, 2008 | 11:54 AM
MTBSully's Avatar
Default What Ignition Box
What Ignition Boxes are you guys using? Ive been looking at the 6AL and the mallory 685 but am interested in other options. What units have timing retard built in? Do i need to buy a harness or something no matter which box i buy? Thanks guys
Old Dec 3, 2008 | 02:46 PM
LT1 > LS1's Avatar
I know a guy that hooked up a 6AL onto his LT1.
it was SUPER easy he said. thats the box I am gonna use too.
I believe the 6al will be perfect for whatever your tryin to do. I am gonna set mine up to automatically pull timing when I have the nitrous armed.
Old Dec 3, 2008 | 02:54 PM
blackz6sp's Avatar
Ive got a digital 6 works great and has the timing retard built in it.
Old Dec 3, 2008 | 03:23 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I am running the MSD Digital 6 also. And yes the adaptor harnesses will make the installation much easier and I highly suggest using them.
There are many options for ignition boxes out there.
The 6A/6AL do not have timing retard built in but that option can be added with another module. Most boxes will either include timing retard or have a module you can add to retard timing.
We carry most ignition box options with the Mallory 685 and the Digital 6 being the best sellers
http://www.nitrousoutlet.com/catalog...el=141&dept=11
Old Dec 3, 2008 | 03:33 PM
LT1's Avatar
LT1
Im running 6AL, with the harness, works good. Im not running nitrous or force induction though.
If you get the 6AL, I do recommend the harness so that you wont have to splice the factory harness.
Old Dec 3, 2008 | 03:58 PM
kinglt-1's Avatar
I had an accel 300+ box, I swear it aided in burning up the opti @ 34,000mi. I would go with msd digital 6 or mallory 685.
Old Dec 3, 2008 | 04:09 PM
SRZ's Avatar
SRZ
Crane HI6R here w/ no issues. Easy to install and packs a spark.
Old Dec 3, 2008 | 04:55 PM
MTBSully's Avatar
does the 685 come with timing retard built it? what about ther crane HI6R? Also, Ray, where can i get an adaptor harness? Thanks guys
Old Dec 3, 2008 | 04:58 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
The 685 has timing retard, 2 step and a window switch built in...we can get the harnesses also....I have been trying to get them to add them to the website.
Old Dec 3, 2008 | 05:03 PM
speed_demon24's Avatar
I loved my 685... wish I never got rid of it when ditched my nitrous. That 2-step was awesome for 6-speed launches.
Old Dec 3, 2008 | 09:08 PM
MTBSully's Avatar
what is a window switch? also, does the 685 need its own specific harness? or could i use an MSD one. I can't seem to find a mallory harness on Jegs.
Old Dec 3, 2008 | 09:15 PM
porksoda's Avatar
A window switch is used for nitrous to set a specific RPM window for the nitrous to activte and deactivate. As for the harness yes you can use the MSD harness. I actually use the 685 box and MSD harness.
Old Dec 4, 2008 | 03:04 AM
robsquikz28's Avatar
well NOT TO HIJACK THE THREAD but i do have 2 mallory 685 boxes for sale if anyone is interested pm me
685 is the way to go
Old Dec 13, 2008 | 06:45 PM
MTBSully's Avatar
which 685 box are you guys using?
This one:
http://www.jegs.com/i/Mallory/650/6853M/10002/-1
or this one:
http://www.jegs.com/i/Mallory/650/685/10002/-1#
Old Dec 13, 2008 | 08:39 PM
BOLO's Avatar
I used to run the original MSD6A for the longest time, but upgraded to their MSD digital 6 box after adding NX150 kit to the car last year.
Old Dec 13, 2008 | 08:56 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by MTBSully
the 685...the first one you linked to is the 6853M
This is the right one
http://nitrousoutlet.com/catalog/pro...roduct_id=3200
Old Dec 14, 2008 | 03:27 AM
Speed Density's Avatar
hashtagBMW
I use a Digi6 on my car, box is pretty solid with its timing retard.
Old Dec 14, 2008 | 11:43 AM
FASTFATBOY's Avatar
A VERY prominent tuner told me an Accel 300+ was worth 3 rwhp on the chassis dyno. Now before you jump me...when he dynos a part to see if it helps the car he makes 3 pulls, puts the part on makes three pulls, takes the part off and makes three pulls. He said an MSD made no power over stock Ignition.
Now to put some more poop in the pot I have an Accel 300 on my car. I adjusted the valves warm, but the valvecovers back on and it would not start. Bypassed the box and it fired up. This was the same day I ran my best ever pass, the 10.84. It ran the 10.84 on stock ignition, with 12.5 to 1 compression.
With that said, makes me wonder if these cars even need an aftermarket ignition.
Old Dec 14, 2008 | 01:39 PM
hashtagBMW
I wouldnt use a box unless you have a power adder that needs retard or somethng along those lines. People get carried away with ignition boxes and there really isn't a point to slap one on top of the stock sytesm unless, again you need some of its features
Old Dec 14, 2008 | 01:52 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
agreed...have seen way to many issuess with nitrous car running stock ignition components that were fixed by an aftermarket box and coil.
