388 LT1 guys in here
Thanks in advance
Dave
Which Procharger model do you want to use?
How fast do you want to go?
All of those things influence you choice of cam and the head design required to accommodate the goals.
Mike is a smart guy, took a 1200cfm T-trim to low 10's in a heavy car if I remember right.
As for procharger setups I would go D1SC or F1A, both self contained systems and can make big power
Seeing 9LBs of boost at 5800 RPMs ( max spped for my SC unit )
480 RWHP.
( I need a bigger super charger! )
If you're running a prochager you should go with the new 227 AFR's (full cnc porting) and have the intake ported to match. You might want to run the monoblade throttle body as well to complement the set up.
I'd also get a professional recommendation for the cam.
As for the F-1R, it is rather peaky, so unless you plan for something well over 20# boost the F-1C will be a lot better as the boost curve is smoother.
For 12-20# the F-1 should be pretty good.
The .060 over is not the best setup, but you may want to consider doing a partial block fill to stabilize the cylinders.
What are you looking for with regards to power, drivability & fuel type? Knowing this you will get some better recommendations more suitable to what you are trying to do.
