Trick Flow 21 Degree LT1's - Info & Pics
Old 07-31-2009, 03:01 PM
  #121
enjoi355's Avatar
lol, sorry if im being impatient, im just really curious to know where exactly they are at because my 355 needs a new set for my cam... i emailed TFS about a month, month and a half ago and they said theyd be shipping in two weeks, i even proposed they make an ltx specific intake manifold, but i dont think they went for it, lol
Old 07-31-2009, 03:57 PM
  #122
1badzee's Avatar
Considering the stock manifold flows plenty out of the box, anyone creating an aftermarket LTx manifold would be pretty much wasting their time. The "big dogs" that require custom sheetmetal manifolds and whatnot will probably go to Wilson Manifolds, which is tested and proven. In any case, there aren't enough of those "big dogs" to justify a company researching and developing an aftermarket ltx manifold. It would be cool though
Old 08-03-2009, 11:09 AM
  #123
want297z's Avatar
I wouldn't mind seeing a little update either. Just to say we are here now, but we plan to try to get to here.
Old 08-04-2009, 08:39 AM
  #124
Advanced Induction's Avatar
Smile
Finishing up the first 21deg TFS based offering now. As soon as we can, we'll put up preliminary pricing & info for you guys.
Old 08-04-2009, 10:42 AM
  #125
Puck's Avatar
Very cool
My main build doesnt need heads anymore, but I have the last shortblock from the car awaiting a mild 355 rebuild and would love to step up from the ported stockers it has now .
Old 08-06-2009, 03:39 AM
  #126
enjoi355's Avatar
i emailed summit and they said
"Response (Zack) 08/04/2009 09:16 AM
TFS-30400008-CNC 1495.95 in stock
You can call 1-800-230-3030 to order. Thanks"
Old 08-06-2009, 09:26 AM
  #127
camar0corey's Avatar
Well yeah you can probably get them as cast right now. Actually if you plug that part number into their website, it still doesn't show them.
Old 08-06-2009, 10:27 PM
  #128
FLN-LCKY19's Avatar
Hey all, I just placed an order for the set and my order status page has a link to the part directly. Try this short cut and see if it works for you.
http://www.summitracing.com/parts/TFS-30400008-CNC/
Should be here Tuesday. I cant wait to top off my new 383!!
Steve
Old 08-06-2009, 10:42 PM
  #129
Yep that one works.
Old 08-07-2009, 01:10 AM
  #130
enjoi355's Avatar
can you please take pics when you get them, i wanna see if they are semi cnc'd and how nice these heads are gonna look
Old 08-07-2009, 08:30 AM
  #131
There are pictures of the minor cnc blending TFS will do to the as-cast head here.
Old 08-07-2009, 11:17 AM
  #132
FLN-LCKY19's Avatar
No, problem bud. They should be here by Wednesday. I sure do hope they look like the pics that AI has posted. I will post a few shots once they arrive to compare as shipped assemblies.
Old 08-07-2009, 11:41 AM
  #133
want297z's Avatar
Steve
Can you provide a before and after dyno of just the head change? Or is this more of a complete rebuild of the engine? Just wondering as I would like to see what the difference is in just these heads alone.
Old 08-07-2009, 12:33 PM
  #134
grn95t/a's Avatar
hey steve, glad to see your getting closer to being done with your build. mine is done and running, but needs to be tuned really really bad, lol!
Old 08-07-2009, 02:23 PM
  #135
enjoi355's Avatar
those pics were from when you guys got the "prototype", ive seen them but was wondering if they had changed from then to now, they are nice like that and hope they stay like that
Old 08-11-2009, 09:42 AM
  #136
LS1Tech Sponsor
TrickFlowTech's Avatar
They are the same as you seen in the pics.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 08-11-2009, 04:54 PM
  #137
TravisMcGill2000's Avatar
have they released the flow numbers for the things yet?
Old 08-11-2009, 09:49 PM
  #138
FLN-LCKY19's Avatar
I couldn't tell you what the difference is. When I got the car it had a Jasper Reman that was putting out maybe 200hp tops (best guess). Took the top off for a Cam swap, head gasket and valve train update and saw that the cylinders and pistons were toast. That was a year and half ago. Now I have a 0.030 over 4-bolt with a cast eagle crank/rods and forged SRP pistons at 10.9:1 comp. Its got a comp cams XFI 280 cam, along with an all comp cams valve train, the new trick flow 21* heads, MSD opti, 30lb injectors and all new sensors and supporting parts. Once its all back together I'm planning to take it to a local shop for a dyno tune.
Im hoping to be a little better off than I was before the teardown. Got my fingers crossed.
Steve
Old 08-11-2009, 09:58 PM
  #139
FLN-LCKY19's Avatar
Default Heads Finally Arrived!!!
Hey all,
Just an update on the heads. They finally arrived.
Here are a few pics of what was in the box.
http://s302.photobucket.com/albums/n...uperman/Heads/
Old 08-12-2009, 06:07 AM
  #140
n2oblkz's Avatar
Since these heads are 21 degree heads, will the standard LT1 headers and intake work with them?
Quick Reply: Trick Flow 21 Degree LT1's - Info & Pics
