Opti
Old Dec 10, 2008 | 05:47 PM
Dendyc's Avatar
Default Opti
Well I got my opti in today...after the car has been dead since October 18th....God I hate being broke.
I am having to do the install in front of my apartment on the ground--I am a bit scared of the install because I haven't really found a good solid write up (I've read the one that used to have pics and found a couple others) just wanted to know any tips and advice you guys had...I know I need to locktite the rotor screw.
Parts I need:
1) Opti (got a delphi from thepartsladi)
2) Water pump gasker (I assume its available at auto zone)
3) RTV (for the water pump gasket and bolts??)
4) Antifreeze for refilling the radiator ( what are your reccomendations?)
I'm prob forgetting something but feel free to add anything and any advice.
Old Dec 10, 2008 | 06:01 PM
LM97Z's Avatar
The o ring gaskets for the WP shaft, you can get both the WP houseing gaskets & O ring gaskets @ your local GM dealer, you should already have new O rings for the opti shaft, just take your time on the install, the only real problem i ran into was getting the opti to allign up once the slot was in the cam, its that outer curcled part in the back of the opti houseing, you have to get it just right so it will fall in place, its like a 1/16 of an inch or so that slips in to keep it centered, you'll notice if its not on all the way in (flush), the opti will rock from side too side alittle & there will be a small gap between where it mates, just be careful, because you can crack it if its not flush & you tighten down the bolts. Just a tip.
Old Dec 10, 2008 | 06:11 PM
juanito's Avatar
replace the seal around the opti where it meets the timing cover. get some PB blaster for the harmonic balancer bolts.some degreaser to clean all the crud on the timing cover if you have any. good luck. ive done it 3 times( not all on my car) . its not that bad. Longtubes is another story!!
Old Dec 10, 2008 | 09:26 PM
koolaid_kid's Avatar
This may help:
\http://www.lt1engine.com/tech/93-97-...emove-replace/
Best of luck.
Old Dec 10, 2008 | 09:31 PM
sweetbmxrider's Avatar
you need a pulley puller. don't rtv the waterpump gaskets, i wouldn't do the bolts but thats personal opinion. the other seals as mentioned. patience....
Old Dec 10, 2008 | 10:37 PM
Bad Lt1 Camaro's Avatar
Should find the gasket at advance auto parts, and as for the antifreeze my car has a sticker under the hood saying it requires a special dextron extended life but you might not have to worry about that. you can never go wrong with a 50/50 mix
Old Dec 10, 2008 | 11:23 PM
Dendyc's Avatar
How badly do I need a torque wrench to get the balancer pulley to 75lbs and the water pump to 31?
I don't have one which is why I am asking.
Old Dec 10, 2008 | 11:33 PM
the_merv's Avatar
Veteran: Air Force
I've never pulled the Timing Cover for an OPTI change..
I've used RTV on the Water Pump Gaskets..I just spread very little bit of it all over the Gasket to get it sticky and I've never had any problems.
Get you a Bucket and a Pan so you can put the Coolant in it when you drain it.
I wish I was in town cause I still have a Seal Kit for the LT1 '95 Timing Cover if you do pull it..lol
Old Dec 10, 2008 | 11:43 PM
Dendyc's Avatar
What is the benefit of pulling the timing cover?
Old Dec 10, 2008 | 11:46 PM
cammed93TA's Avatar
Parts I need:
kinda pissed my partladi opti was DOA.
Old Dec 10, 2008 | 11:54 PM
the_merv's Avatar
Veteran: Air Force
I don't know, I've never done that for just an OPTI change. If I remember right, you can chance the OPTI Seal with it still on the Car..
Old Dec 10, 2008 | 11:58 PM
spm4520's Avatar
There is NO need to pull the timing cover to change the Opti. I fought opti probs on my '93 for about 6 months. I literally had Opti's in and out of that thing nearly a dozen times for various reasons. I never once used gaskets, RTV works fine. The hardest part of the whole job is actually wrestling the water pump out after is loose. It's not a difficult job. Go for it.
I purchased a couple from thepartslady and was very pleased with the transactions.
BTW, after you realize Opti's totally suck, do what I did and go with a coil conversion kit like I did.......I went with a Delteq and haven't had a problem since! I spent as much replacing Opti's as I did on the Delteq, wish I had done it the first time.
Old Dec 11, 2008 | 12:13 AM
Dendyc's Avatar
Delteq's would be nice except for the fact that we can barely afford groceries let alone performance parts.
Anyone want to comment on the torque wrench?
Old Dec 11, 2008 | 12:40 AM
the_merv's Avatar
Veteran: Air Force
I did the Coil Conversion too.. lol
I never used a Torque Wrench, just put them on there tight.
Old Dec 11, 2008 | 07:45 AM
I used a torque wrench on my current engine build. However, if you have done enough bolts, you can usually tell when you have tightened it enough. You can get a torque wrench at Harbor Freight for $20 if you need one.
Old Dec 11, 2008 | 08:15 AM
Javier97Z28's Avatar
You can get away without a torque wrench for an opti job.
Don't use RTV on the bolts, use permatex thread sealant on the WP bolts. A little dirt in the bolt passages and you could end up with a leak at one of the bolts if you don't use sealant.
I use a "smear" of RTV on the WP gaskest to hold them on the block to make the job easier. It's not necessary though, the gaskets seal fine.
Old Dec 11, 2008 | 08:45 AM
the_merv's Avatar
Veteran: Air Force
Pretty much what I do..
Old Dec 11, 2008 | 02:37 PM
Dendyc's Avatar
If anyone in Central AR would like to get together or help work on it I'm in Conway!
Old Dec 11, 2008 | 06:26 PM
Dendyc's Avatar
About the locktite on the rotor screw...I was looking at this thing and how the hell do I get it apart? Is it needed on a new OEM piece I know it is reccomended on the aftermarket ones.
Old Dec 11, 2008 | 06:31 PM
1badzee's Avatar
How do you get the rotor off? Is that what you're asking? It's a small torx bit - I believe a T6 or T7
