what does it take to go to a monoblade TB?
Old Dec 14, 2008 | 10:53 PM
Formula350's Avatar
Originally Posted by 96capricemgr
Dumps into the plenum right behind the blade, the IAC circuit in the manifold is not used because the hump that connectsit to the TB get cut out.
I made my TPI intake which I believe would've allowed it to accept a monoblade and was able to leave that hole in the intake. Assuming we're talking about the same spot, triangle on TPI circle on LT1. But I don't recall that triangle being either that large or a triangle, but it's been a good 6 years since I siameses it.
https://www.epsb.net/~mstrembi/plenum.jpg
http://www.injuneer.com/images/photo.../DCP03751a.jpg
And when I want to find it again, I can't. The one pic I saw for the Mono had most of the middle hump removed, but just enough to still keep it mostly there but allow for the monoblade. I'm sure that would've made things easier.
Old Dec 14, 2008 | 11:10 PM
SoxXpupPeT's Avatar
dont waste your money. there are things like headers, catback, CAI that need to be done first. a larger TB isnt needed until a head cam swap. and even then its not necessary on all cases
Old Dec 14, 2008 | 11:26 PM
sweetbmxrider's Avatar
do your suspension before a tb. you seem to have most of the motor bolt ons.
Old Dec 15, 2008 | 12:46 PM
formulabrandon's Avatar
your crazy if you think pulleys dont make a difference. no they dont produce power but they free it up. i put march pulleys on my car and dropped .3 and i could notice a big diff in the seat of paints test
Old Dec 15, 2008 | 02:17 PM
AChotrod's Avatar
Pulleys work and yes a stock TB can support up to 400hp but it sure wont help you get there. If you do buy a TB just get a 58mm and be done with it since we know there will be more mods down the road!!!!
Old Dec 15, 2008 | 03:59 PM
C_Rules's Avatar
3 tenths with just pulleys sounds like a bit much. did you do anything else? was the weather and DA alot different?
Old Dec 15, 2008 | 04:13 PM
xx_ED_xx's Avatar
It takes money to get a mono blade. Figured I would state the obvious.
Old Dec 15, 2008 | 04:36 PM
bowtiekid's Avatar
Well if you didnt know or hasnt been stated already. The stock LT1 TB will support 400 horsepower fine. Anything above that I would change it or port it
Old Dec 15, 2008 | 05:36 PM
96capricemgr's Avatar
Completely removing the belt is only good for .1 in most cases, your test revealing .3 was somehow flawed, like the ther poster said, maybe it was weather, but one way or another you are wrong.
Old Dec 16, 2008 | 12:21 PM
impaled's Avatar
i agree. i say it would be a stretch to even pick up a tenth with just pulleys. much less noticable power on the street.
Old Dec 16, 2008 | 12:23 PM
impaled's Avatar
already have full BMR everything and konis in the rear.
as stated already have all other boltons, and headers are on the way.
Old Dec 16, 2008 | 12:54 PM
  #32
yeah your right i forgot it was at two diff tracks . one was ic st.louis one in pa
Old Dec 16, 2008 | 01:26 PM
  #33
1989GTA's Avatar
I have installed a AS&M monoblade on my TPI. I removed all the material between the two bores for one big oval at the plenum entrance. The IAC air intake is before the throttle blade and the exit is a little past the throttle blade. It idles fine with no problems.
Regarding the monoblade and the LT1 type induction system. I have heard from more than one person that a modified LT1 can benefit from a monoblade. These opinions are based on dyno runs.
One more thing. If installing a 1300cfm monoblade it would not do much good if you air intake system is not capable of supporting that much cfm.
Old Dec 16, 2008 | 02:43 PM
  #34
AChotrod's Avatar
Hmmm I wonder if it would do anything for my ride? At the motor Im probably making right around 500hp maybe a bit more.
Old Dec 16, 2008 | 03:05 PM
  #35
Formula350's Avatar
First I would look into upgrading to a custom CAI with bigger plumbing. If that helps things out (*** dyno I think would suffice) then it's possible.
Old Dec 16, 2008 | 04:18 PM
  #36
AChotrod's Avatar
No need I have ram air
Old Dec 16, 2008 | 11:56 PM
  #37
Formula350's Avatar
I don't know what it can do, but I'm not sure if the factory (or aftermarket) ram air can do 1000cfm (58mm) or 1300cfm (monoblade) for that matter :\
Old Dec 17, 2008 | 11:21 AM
  #38
AChotrod's Avatar
Im not sure either LOL! Thats why Ill never buy a Mono. Just wondered if my car would see anything from it
Old Dec 17, 2008 | 11:26 AM
  #39
transamws6_97's Avatar
I don't see why w/ smooth bellows that the ram air intake wouldnt flow? the biggest restriction will be the maf which is in either intake and there are no bends.
Old Dec 17, 2008 | 11:35 AM
  #40
AChotrod's Avatar
Oh hands down the LT1 Ws6 Ram Air will out flow anything else IMO just not sure that I would see gains by going to the monoblade over my 58
