Rear end going out?!
Old Dec 13, 2008 | 01:24 PM
Bad_tx_Z28's Avatar
Angry Rear end going out?!
I cannot begin to explain how frustrated i am right now . For about a week now i've noticed my rear end make queit a bit of noise. I know that most of it is from the richmond gears. But, now it seems like the howling is getting louder. I've also noticed that when im shifting from park to reverse, i hear a pop, the same when i shift from reverse to drive. The howling really seems to get loud when i decelerating. Any thought guys?
Old Dec 13, 2008 | 01:34 PM
IronOutlaw's Avatar
I would change/check the fluid in it before doing anything else.
Old Dec 13, 2008 | 02:10 PM
Bowtie_Aaron's Avatar
check the fluid.
but i am willing the bet it needs new bearings.
my jeep did this AFTER i added about a pint of fluid, it got super loud and i rebuilt it with new bearings and seals, and had to replace a spider gear and it is dead quiet.
bearing kits are cheap, and lash doesnt have to be set. there is a special tool to make installing the carrier bearings much easier, but thats it.
aaron
Old Dec 13, 2008 | 02:39 PM
the_merv's Avatar
Veteran: Air Force
Check to make sure the Pinion is tight..
And stop picking up the Fat Chicks..
Old Dec 13, 2008 | 02:49 PM
Bad_tx_Z28's Avatar
very funny merv. I cant help it! there too sexy.
well, my next question would be this. My mechanic installed the gears in april of this year. I gave him a complete rebuild kit. He said the only thing he had to replace where the seals. He said that the bearings looked like new so he didnt bother with them. Could they have gone bad in that short amount of time?
Old Dec 13, 2008 | 04:07 PM
the_merv's Avatar
Veteran: Air Force
If the Crush Nut came loose then that could lead to problems..personally if I have new Bearings, I put them in while I'm there. Regardless of how they looked, you are paying him to do the Job, and he should have done it IMO..
Bad_tx_Z28's Avatar
anyone?
Old Dec 13, 2008 | 04:47 PM
Jonez_z's Avatar
(fat bitches need love too)
Old Dec 13, 2008 | 05:43 PM
ditto..
no matter how good the bearings clean up, replace them.
aaron
Old Dec 13, 2008 | 06:08 PM
Bad_tx_Z28's Avatar
well i guess im taking that bitch back to shop monday and see what he says.
Old Dec 13, 2008 | 06:11 PM
shtnfrds's Avatar
i wouldnt have taken the car back if you bought bearings for it and the "mechanic" said they looked good cleaned up. sounds like he wanted a quick dollar with minimal work.
Old Dec 13, 2008 | 10:30 PM
-DIABLO-'s Avatar
agree i was driving my car on the highway last tuesday and it did the same as soon as i let go of the gas it would start making an ugly noise so pulled over and luky me i found a shop as soon as i exit the highway so they lift the car and all it was the pinion got loose i didnt tighted enough
Old Dec 14, 2008 | 03:20 AM
Bad_tx_Z28's Avatar
then again, parts of me just wants to go out and drive the **** out of my car until the 10 bolt breaks. then i would have somewhat of an excuse to upgrade...
Old Dec 14, 2008 | 03:36 AM
the_merv's Avatar
Veteran: Air Force
^^You say that now, but then when it's down for a month and you are under it wrestling with the 70lb Center Section of the Moser 9"..you will wish it was on the road..lol
Old Dec 14, 2008 | 09:34 AM
harner's Avatar
So I'm not the only one with Richmonds that sound like an air raid is going off inside the car?
I had mine installed over the summer. Had it at the track and the gears are still quite loud. I think it's because the straight cut. Noisy!
Let us know how you make out.
Old Dec 14, 2008 | 09:38 AM
Bad_tx_Z28's Avatar
^^ yeah i know thats one of the main reasons that im having a buch of noise back there. I have been hearing that sound for over 6 months. So i know how it sounds, but here recently the sound has changed. So i hope i iget a good diagnosis tomorrow.
Old Dec 14, 2008 | 10:51 AM
my richmonds in my chevelle are not noisy at all quiet as can be.
aaron
Old Dec 14, 2008 | 01:59 PM
Bad_tx_Z28's Avatar
i have always heard that richmonds are a bit louder than other...
Old Dec 14, 2008 | 02:09 PM
SmokedOutZ28's Avatar
Mine was doing the same thing.... 10 minutes later I got a excuse to upgrade!
Old Dec 14, 2008 | 02:13 PM
AChotrod's Avatar
I always heard stay far far away from Richmond gears! Only go with Motive or GM gears
