too many choices!
thanks in advance,
kevin
The converter selection will depend on the camshaft you select.
You need to answer some questions to be able to be given a good camshaft recommendation:
Need to pass emissions?
How high are you willing to rev?
Daily driver or weekend warrior?
Want a strong bottom end, midrange, top end or what combination of them?
There are many more but just those 4 would reveal alot.
If you don't have to pass emissions then I would bump up the RPM's to say 6100-6200 and get either Lloyds version of the Crane 227 or the H/C. Those are still emission cams but being you don't want to go too high you are kinda stuck choosing a emissions cam. In fact, Lloyd is sitting on a baby cam I sent back to him and I'm sure he would give you a good deal on it. It's his version of the 227 which would give you a ton of low end and it would die off around 5800rpms. Match that with his LE2 heads, some Long tubes and you would have a strong running LT. You would be somewhere in the 355-365rwh range with that set up with the supporting mods.
Yank or Vig stall.
Depending on the money you have both of their heads are great so if they are in budget plan for more hp. Which will require more money for more supporting mods. Its a never ending soga.
