cam advice please!
Old Dec 17, 2008 | 01:59 PM
93TAJ.C.'s Avatar
Default cam advice please!
I'm pulling the lt1 out this weekend, im throwing on some longtubes and already have a k&n fipk cold air intake (yes i know, its way too expensive). I was wondering what cam and springs would work the best with the stock heads. I already have comp cams 1.6 rollor rockers, i just need springs and cam. Any advise is gold right now!!!thanks!
Old Dec 17, 2008 | 02:00 PM
Elliott's94Z's Avatar
Do you need to pass emissions?
Old Dec 17, 2008 | 02:06 PM
93TAJ.C.'s Avatar
nope! I was also going to add that i want something that will be ok on the bottom end and doesent need gobs of rpm's. I will also have the pcm tuned by pcmforless along with the mods.
Old Dec 17, 2008 | 02:08 PM
Check out this link and see if anything sparks an interest. I got mine from Lloyd and it's a quality product. http://www.elliottsportworks.com/lt1.html
Old Dec 17, 2008 | 02:11 PM
93TAJ.C.'s Avatar
yeah i was actually going to have him do my heads this winter but am realizing i wont have the money I'd rather wait and do it right than risk killing a good set of heads.
Old Dec 17, 2008 | 02:16 PM
Did you look at the cams on the site though? This one might be of something you may be interested in..228/235 .560/.560 109 LSA. - 1900-6200 It would be a strong running cam and be just fine on the bottom end. He can always custom grind you something as well. That's the route I went..
Old Dec 17, 2008 | 02:20 PM
93TAJ.C.'s Avatar
yeah thats the one that caught my eye! I think hats what ill go with. Now i just need everything else ahah
Old Dec 17, 2008 | 02:25 PM
With that cam I would def change your gear ratio out..do you have a A4 or M6? If you have a A4 I would rec. a 3.73, M6 the same or 4.10's
Old Dec 17, 2008 | 02:50 PM
z28rob18's Avatar
if ur interested im sellin a cam right now its brand new i changed my plans heres a link to it on jegs.
http://www.jegs.com/i/Edelbrock/350/2108/10002/-1#
Old Dec 17, 2008 | 03:00 PM
What are the specs of that cam?
Old Dec 17, 2008 | 03:17 PM
z28rob18's Avatar
at .050 its 218/218 and 525/525 lift
Old Dec 18, 2008 | 01:35 AM
LM97Z's Avatar
I'll be getting my cam from Lloyd, i'm staying with the 3.42 gears with full bolt-ons, this is what he spec'd out for me running an M6 @ full weight.
non-emissions: 565/565, 223/230 @ 50 on a 110 LSA
emissions: 565/565, 223/230 @ 50 on a 112 LSA
Old Dec 18, 2008 | 01:10 PM
krill's Avatar
Im also selling a cam right now, lol
Its a LE1.2 cam
Heres Lloyds quote about the cam:
It was designed for low and mid range power (1700-6100 RPM), has great drivability and an idle similar to Hot Cam or CC 503 cam.
Used for 500miles, 180 shipped!
22x/22x .570/.570 10x LSA
Old Dec 18, 2008 | 01:28 PM
camaro-94-z28's Avatar
heres a great thread to read
https://ls1tech.com/forums/lt1-lt4-m...wap-guide.html
