LPP LT advise with install
Thanks!
Before the clearancing, they would just barely touch. Clearly this would be an issue under twist as well as when the rather new motor mounts normally start to wear and things begin to move.
I took no chances on this because I did not want this to result in banging noises, possible broken header flange welds or false knock retard.
I suggest you fix this before it becomes a problem.
A lot different then the Pacesetters...
