lt1 runs on ls1 computer using modded OPTI
i ended up getting a harness, coils, and pcm from a 99 truck for 100$
i got efi live used for 300$ with one vin left on it.
i repinned the lt1 harness into the truck ls1 connectors for free
now to get this harness, pcm and coils for 100$ i went to the local yard and took it off myself. it may cost more at a larger yard if you just want to walk up to the desk and have them hand it to you.
if you pruchased off ebay you may pay 75$ for pcm 75-100 for coils, and 100$ for the harness (you would be chaper to buy the needed connectors)
efi live new is 550$ with 2 vins..
Would you be willing to share the info on repinning the harness to the people who buy your opti conversion?
or you could upgrade to the larger ls maf i grabbed one from the truck i got the harness and pcm from and it looks like it would flow a substatial bit more air.
i however am planning to go sd with my 2 bar tune
yes i would need to know the year then i would give a pinout diagram that would say somting along the lines of
lt1 black connector ls1 blue connector
23 blu/wht >> 34
you would take the blue/white wire from the lt1 black connector in hole 23 and put it in the blue ls1 connector hole 34.
i can also supply the actual wiring diagram from your car and the ls1 car so you can compare as you go along.
i would also reccomend labeling the wires before you pull them out incase you ever have to go back, or you plug one in the wrong hole.
If I could junkyard build this for around 500 bucks and install everything myself, which should be possible at these huge FL "you-pull-it" junkyards, I would be saving over a grand that I was planning on spending for an aftermarket system. I wouldn't need EFI live or anything since my tuner can take care of all that for me - I'll trailor the car to him if need be, my shop of choice is a whole 10 minutes from me
.This is especially good news for us 93 guys who are tired of using piggyback chips and emulators...or even worst, UV flashed PROMS
things that may not work
traction control (may not work not 100% sure)
egr (wont work) could easly make a adaptor plate to mount ls style egr.
skip shift dash light (may not work) << who cares, skip shift will still work the dash light may not iluminate.
94, and 95 auto tranny need modification to work
On the flip side... Those of us who don't have the money to get tunes or buy the tuning software, that leaves us 93 people just as stuck. Because you either have it done totally right the first time, or you have to get updates done later on. There's some cheap burners on eBay for $15~ that would be much more worth the time.
my tach was working.. it needed to calibrated but all the tools are provided in efi live.. i cant however argure about the spedo as i never had it moving but it should work when calibrated.
I have a 97 so I should be good since it's an LS1 cluster
We have done a few LT1/LS1 engine swaps and with a Speartech converted harness the dash has worked for us.
has anyone been able to get the 95 and older cluster to work on ls1 swap using efilive? i know hp tuners have far less options in this area, mabey that is the reason people have issues?
mabey i will put the car on 4 jack stands and do the ferris buler..
