lt1 runs on ls1 computer using modded OPTI
Old Jan 5, 2009 | 05:29 AM
  #61
AKAFRED's Avatar
i am working on sourcing the disks. i should know shortly
Old Jan 5, 2009 | 11:48 AM
  #62
AKAFRED's Avatar
I have ordered 10 optical disks.
Old Jan 5, 2009 | 11:50 AM
  #63
AZ2ENVY's Avatar
Badass !!!!!!!!!!!!
Old Jan 6, 2009 | 10:22 AM
  #64
Grr's Avatar
Grr
I would like to buy one of them please
Old Jan 6, 2009 | 10:24 AM
  #65
Tricked-Out-Toy's Avatar
Awesome! when do you think you will get the tech write up together?
Old Jan 6, 2009 | 10:44 AM
  #66
Cross's Avatar
Originally Posted by Grr
if you can have a couple of those wheels machined and give a quick write up of the wiring, i will paypal you $$ as soon as you want it. PM me if interested, or i will pay for the file to machine my own wheel
Gary
Myself as well
Originally Posted by AKAFRED
i am working on getting parts to make 2 more of these. i will then sell them at a reduced rate to someone in a warmer area so that it can be verified on a moving driving car..
if that doenst work then i will have to wait untill spring when the snow goes bye bye..
I also already have a 2000 PCM, Coils and Wires so I am ready to go. And I live in Tucson, AZ so yeah its warm here.
I am also just finishing with my motor build this week and getting back on the road. I would be happy to drive up to NicD's and see what he thinks tuning it. I think that would be one hell of a source of tuning information for you. (He is only an hour and a half away from me anyway and I was going to go see him to have the LT1 ECU Tune checked, I would rather just do this)
Just let me know if you want to take me up on my offer, I am in either way.
Old Jan 6, 2009 | 10:51 AM
  #67
Fire67's Avatar
I have a .dxf of a wheel to use for aftermarket computers to get the signals. I have intended to do this to make my FAST run sequential with the Opti in place. It would save a butt load being that I would not need to purchase a crank trigger and cam sync.
PM sent concerning getting my .dxf cut out.
I can test it almost immediately as well. It would not be the same as testing your setup with the LS pcm, but it could be proof that it works in a running, driving car.
Old Jan 6, 2009 | 04:19 PM
  #68
Ralls's Avatar
So if I'm understanding this right, any optispark will work... Vented and non-vented?
And any 93-97 f-body is capable of doing this setup?
No requirement for a certain timing cover or other specific part?
Old Jan 6, 2009 | 08:26 PM
  #69
AKAFRED's Avatar
yes this shoud be compatabable with all years. if any one has a 93 or 94 opti they are willing to give me to take apart and verify send me a pm
Old Jan 6, 2009 | 09:03 PM
  #70
AKAFRED's Avatar
no dxf's will be provided.
i may be able to design a opti that ouputs the signal your looking for, you would have to know what pattern is needed thou.
Old Jan 6, 2009 | 10:46 PM
  #71
Cross's Avatar
I PM'd you back I am in lets do it!
Old Jan 7, 2009 | 09:18 AM
  #72
AKAFRED's Avatar
Automatics
i have been looking into automatics and the ls1 pcm. it appears that the ls1 pcm will control a 96+ tranny as is, but there may be some issues with the 95 and older trannys. i have pm'd two of the best tranny vendors on the message board to see if they can help me out whit what would be needed to control these older tranies.
Old Jan 7, 2009 | 09:34 AM
  #73
performabuilt's Avatar
LS1Tech Sponsor
You are correct the 96 up should be no issue, The 93 (truck) 94-95 are a little different ,
the 93 and 94 do not have the PWM solenoid, And has a different 3-2 regulator strategy , However I have in the past done this swap without any decernable issue simply by installing the later harness and adding the PWM solenoid as a dummy and swapping the 3-2 solenoid from the later set up . Some will say there might be down shift issues on the 3-2 but I did not experience this or notice any issue at all.
Another option would be to use the entire valve body assembly from a 96 up trans.
As for the 95 it does have PWM but still has the different 3=2 strategy again swapping the harness and the 3-2 solenoid seems to cause no issue I could detect and caused no problems either short or long term when I have done it and its been years and the cars this was done with have never experienced any issue.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 7, 2009 | 09:46 AM
  #74
Puck's Avatar
Very interested. Being a 93 the computer does not control my tranny anyway.
If I send my working 93 opti would I get it back??
Old Jan 7, 2009 | 10:24 AM
  #75
AKAFRED's Avatar
i would prefer to get one that didnt need to be sent back.. as long as the optical disk is on one piece i sould be able to verify that it will work. or one from a person intrested in the conversion.
Old Jan 7, 2009 | 11:10 AM
  #76
Grr's Avatar
Grr
Yeah, i too would want my particular opti back, as it only has about 1500 miles on it, and dont want someones used up POS on my car. Is that possible? I can get in on this in about 2 weeks if you still have a disk around for me.
Old Jan 7, 2009 | 11:20 AM
  #77
Birdie2000's Avatar
X2, I feel the same way.
Old Jan 7, 2009 | 12:17 PM
  #78
AKAFRED's Avatar
yes sorry i misunderstood pucks question. eariler in the thread i had asked for a early opti so that i could verify that the 93-94 opti would work with the disk i designed for the 95+ model. basically i was / am looking for a old or good one that i could keep. and wouldnt have to worry about shipping back. i would of course pay shipping here.
i wouldnt be offering a exchange service, i would be modifing your opti. you would recive your opti back, i may keep a coulple here for the odd case were you were in a rush and couldn't wait for shipping.
Old Jan 7, 2009 | 12:38 PM
  #79
Puck's Avatar
Nah, you got my question right I was responding to you needing an early opti sample, but I would need it back so I'll just wait until you are all set.
If it works, I will be going with your conversion and saving the $1.5K that I was going to spend on a Megasquirt II setup.
Old Jan 7, 2009 | 12:59 PM
  #80
Birdie2000's Avatar
What do you foresee the overall cost being for the whole upgrade, including your opti modification?
