Cam Heads Combo
I wouldnt jump 96caprice too much... He just cant stand seeing folks make mistakes in their builds and is very vocal about it...I'm the same as him but a little less vocal about it...
My advice is to look at who is going fast and has the type of car/set up you are looking for...The whole car has to work together...Dont get sucked into the big cam is better theory either...I run a 226/234 Joe Overton/Erson grind with Lingenfelter/E.B. Porting heads on my 383 and it is driven everywhere...My dyno numbers make most laugh, but the trap speeds make those same folks cry...
Good luck...
--Alan
I am only running 3400/3.73/27" DOT slick, sport/handling shocks, nothing radical nothing special. It 60fts very well compared to even a lot of stroker cars with more stall and gear in them. Makes great torque below where chassis dynos generally are asked to read which maks it launch and drive well.
Either way you go (AI or LE) you will be happy. Both quality stuff.
Whether your hard up for cash, or have it too spend, he takes the time to give you the ins/outs of what can/can't be done.
A1 is a steak sauce you put on crappy meat when you can't afford fillet mignon.
Ai is name of the best cylinder head/valve train guys out there. They are, in fact, the 'fillet mignon' of the business. A little Ricky Bobby rationale for ya
Oh, and we have & we're going to use it tonight to tag team your sister, GoSlowKid
The second I clicked on this thread I KNEW you'd be all over it, and there you are, post #2. What a shock.
I am not knocking AI at all, they make some great stuff, BUT there are OTHER people who BELIEVE IT OR NOT, know a thing or 2 about making a car go fast. You get so adamant when someone merely suggest checking out a different place, as though you are on the AI payroll or something.
In my experience with AI my heads look awesome really Quality work.
the Camshaft differant story for some reason when I did the motor pushrods were 7.3 Phil from AI couldn't figure it out why so long when the stock were only 7.2 back then he thought my builder did something wrong but 2 yrs later after I rebuilt it again there camshaft had been ground alot smaller the base circle was small but the lift wasn't that big for it to have such a small base if fact my new 227 camshaft has a bigger lift on the exh side and its base is bigger, but anyway thats why I needed longer push rods but I kinda wonder why phil didn't think or know that?
maybe I had a bad grind.
but performance wise maybe it was my set up but thats why i thought you bought custom grinds but what ever there grind wasn't even up to par in my opinion i couldn't chirp in second gear and had lost to a few race's even my nephews 99 TA spank me and hes all stock.
now on my rebuilt LT1 same heads,tranny, verter,new bearings,rings,oil pump,pretty much the same set-up but with the crane 227, BIG DIFFERANCE punch it at 40mph and your burning tires. it pulls hard all the way shift points around 5900rpms I had not had some much fun with this car from the day I rebuilt her.
2 race's aready and hands down wins
Guess 96Capri was right about "Kids" being on here
If I don't work I might be there.
I'm learning how not to punch it off the line becuase the tire's spin like crazy but I will have to take some air out to grab alittle better.
when I raced my buddys firebird ( he wanted to see what my formula could do)
I let him get up on me while I gradualy got on the gas he was ahead of me but once I hit second I gave all the gas and the tires still broke loose and once I got traction I flew past him.
I won't know untill thursaday if I work Saturday but if not I will be there.
I think the ET vs. MPH changes that you are describing are much more of a factor with very low 60ft times or lots of spinning. I probably had 40 passes 96+ mph. In negative 600ft air I went 7.3 at 98.47 with a high 1.6 60ft. My average 60ft was 1.65 to 1.68. My best ever 60ft on motor was a 1.59.
It is hard to hook up a car at a track that is a parking lot during the football games. At our real track I ran 7.29 at 95.6 with a 1.61 60ft. The DA on that run was +2300ft. Do the altitude conversion on that run and my car looks consistent.
My car dyno'd 343rwhp through the th400 in 100 degree heat. I changed the intake and exhaust but added a 9 inch and run slicks. Who knows or cares what it dyno'd on the 97mph runs.
Good parts and attention to detail make for a fast car.
