fans never run
Worst come to worst a Hypertech handheld lets you change your fan settings.
Personally I'd wire up a cheap switch and see if that fixes it.
In my 94 I ran a wire under my low fan relay and grounded it between my brakelines. It was a little ghetto, but i ran it like that for a year and the fans would run when i had the ignition switch on.
Doing this will fix the problem but if you want it "fixed" you may have a problem elsewhere, the fans should be coming on by themselves.
Try testing your relays and see if you can make the fans come on like they are supposed to. I switched mine around with my a/c relay because I knew it was good.
Changing relays wont make the fans run all the time though, just when they are set to run from the factory.
I suggest the A/C relay because you know it is good and you dont need it to run the car. Try switching it with the low speed fan relay and see if they will come on then.
EDIT: I just had a better idea, take your relays out of the fan slots and put them in the A/c slot and see if the A/C kicks on, that will be a lot easier and quicker than trying to wait for the fans to kick on with the a/c relay in.
i didn't know the fans still turn on with the a/c if the relays are bad?
here's some wiring for ya, irocchenault.
http://shbox.com/1/fan_schematic_1995.jpg
http://shbox.com/1/schematics_wiring.html
Last edited by bobdec; Jan 7, 2009 at 10:03 AM. Reason: changed temp sensor in block to temp sensor in head
