what plug
Old Jan 6, 2009 | 03:24 PM
94-lt1's Avatar
Default what plug
what plug should i run in my 94 z28 with a cam and vortech supercharger with 6-8psi
Old Jan 6, 2009 | 04:01 PM
ss.slp.ls1's Avatar
I've been running NGK TR55 plugs in all of my engines. I am happy with them. You'll have to research the optimum gap setting though.
Old Jan 6, 2009 | 04:17 PM
djjab57's Avatar
i just awitched to the NGK TR55 today, all ive heard is praise about them so i went with them
Old Jan 7, 2009 | 02:44 PM
94-lt1's Avatar
will these plugs work for a boosted car
Old Jan 7, 2009 | 02:46 PM
Ihasfip's Avatar
My buddy runs TR6s gapped at .036 .Thats 8psi on a 5.3 though? Don't know if that helps?
D
Old Jan 7, 2009 | 02:55 PM
RamAir95TA's Avatar
I've always understood that TR55s are fine for N/A, but the tighter gap on TR6s is better for N20 and boost to prevent the spark from blowing out.
Old Jan 7, 2009 | 02:58 PM
connexion2005's Avatar
I run tr6 gapped @ .035 for my 12.1 compression. I plan on using them with a 100 shot soon as well. I would run them for boost also since they are a colder plug and better for detonation...
Old Jan 10, 2009 | 05:40 PM
94-lt1's Avatar
thanks for the help.
Old Jan 10, 2009 | 11:02 PM
z28matt's Avatar
+1 ngk tr55
Old Jan 11, 2009 | 03:34 AM
koolaid_kid's Avatar
For boost, it is recommended to go one heat range colder, which is the TR6. And close the gap to 0.035.
Been working for me for 4 years now; pulled the plugs this fall and they looked excellent.
Old Jan 11, 2009 | 09:42 AM
moehorsepower's Avatar
Will they work? Yes...Should you use them in a boosted application? No.. Go with TR6 if you have stock ignition, then close up the gap a little more or you could possibly get spark blow out....
