Where can i get a freaking timing set?!
You can always find lots of part numbers on my Tech Page (link in sig).
F-body timing set part numbers are listed:
1993-1997 stock crank sprocket 10128346
1993-1994 stock cam sprocket 10128349
1995-1997 stock cam sprocket 10206039
1993-1997 stock timing chain 10128485
Listen to this man, he would know.
If it's the original opti, I would replace it now, while it's easy.
I have a very low miles, stock, later year LT1 cam in my garage.
I would just get an oem timing set and get it back together. Later down the road if you have to rebuild the engine or decide to do a cam swap, that's the time to do the conversion.
Me - Can you look up an oil pressure sensor for a '99 SS Camaro
Parts Guy - What kind of engine does it have?
I was like WTF?!
