pulling trans ?'s
Old Jan 7, 2009 | 09:07 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
oo damn i have a extra M6 i pulled outta my car
Old Jan 7, 2009 | 09:20 PM
Razor_Blade's Avatar
Originally Posted by 1slo_camaro
pyro just like you and slagger ive done that on everything else. i just figured this was my lil trick hey we all have our own ways right?
I did the same thing when I pulled mine. Dropping the cross member and tilting it back makes those top bolts easy to get with a long extension.
OP, be careful lifting the car that high on dirt. The jack stands tend to start sinking and fall over. That would be a bad way to go out!
Old Jan 7, 2009 | 09:34 PM
F3RR3T's Avatar
i do have some 2x2 4 inch thick concrete pads i use under the stands.
also what do yall "mean tilting it back"?
Old Jan 7, 2009 | 10:48 PM
slagger's Avatar
[QUOTE
OP, be careful lifting the car that high on dirt. The jack stands tend to start sinking and fall over. That would be a bad way to go out![/QUOTE]
Deffently becareful. on mine I have, 1foot x1foot x 3foot soild wood that has steel bands wraped around them just incase they split.
I also used them on my back tires to raise the car high enough to get my motor out when I rebuilt her.
Old Jan 7, 2009 | 11:08 PM
F3RR3T's Avatar
when yall say tilt it back. are you talking about undoing the trans cross member and letting the tailshaft flex toward the ground using the motor mounts as a pivot?
just never heard this term before
Old Jan 8, 2009 | 12:04 AM
pyro719's Avatar
Exactly. Go get yourself some junk 10 inch wide rims and put them under each 4 wheels. Best jack stands ever! Thats what I use I like to be very safe when im under the car.
