Fastbird93 Single Turbo Build Thread
Show me how many 9 second or faster LT1's are still running opti's.... chances are there are not that many. Not saying there is none but I guarantee if you look under the hoods of the big dogs an opti is nowhere to be found....
But back to the original reason for the post. Sean I love the build. Turbo is the way to go, hence my decision to swap over to one at some point when it's financially feasible....
Still won't be as fast as your car though man!!! Now OUTLAW, do you NEED to run a crank trigger with a dist? Or can you just run the dist. off the cam gear like OG style gen1? Just a idea to save some money if he can
http://store.summitracing.com/partde...5&autoview=sku
good luck getting it to work with a stock PCM...
you'd be up to your knees in wiring...If I was gonna do it i'd do a FAST distributor that they sell with the cam sync.... you won't need to shop around to find plugs or splice any wires.... their dist plugs right into their cam plug on the XFI harness.... no crank trigger required then i think.....
i'm not sure 100%. The way i did mine was the way that I though all the big boys do it.... But I can't run in sequential mode..... when i have the motor out i'll put in a dist with a cam sync and switch my XFI to sequential instead of bank to bank and then i'll be able to tune out cylinder to cylinder lean/rich conditions.....
i went 9.40 with an opti. but never seemed to last... AT ALL. what is more cost effective spending over $500 for a piece of **** dynaspark opti, and then having it break rebuild it...sell it! then what buy another opti, lmmfao!!! last one i had i chucked hard down a concrete floor! batch fire sucks, unless you are running a carb style intake. i have had to make a fair bit of adjustment with the fast to make all 8 cylinders happy with my forward facing lt style intake.
i ran batch on my old accel gen 6, it worked great for what it is! but having the ability to run sequential and not is ashame, but i can also relate to the almighty budget, either way it catches up.
oh and cool build!!! especially since you have a clutch behind it! that simply means you drive the car.... not it taking you for a ride
Fastbird will get by with the opti. he might have good luck with it.... I ran all the way down to 10.40@131 with my little 355 with the ORIGINAL opti so i don't hate on opti's cause i had bad luck like taner and alot of others.. mine provided me great service... But to me I don't like to be "THAT GUY" that talks big **** then goes to the track and has to tell ppl "well my opti crapped out which is why my car is breaking up and only running 13.7"..... Nobody ever respects "THAT GUY"...... I know a few of them at my track. The ones with a claimed 800hp-1000hp but they've got a 10 bolt and sticky tires
In fact his buddy has a late model mustang (yea you heard me right, mustang
,lol) that has a 383 LT1 in it with Nitrous and F1R hoping to go 7's i'll check it out.... Yeah i figured it had to be something (chassis swap) cause you'd have to make an assload of power to run mid 8's in a 3400lb f-body... that's alot of power for the stock PCM. a chassis change to something lighter makes alot mroe sense....
mustang with an LT1.... interesting....
