Fastbird93 Single Turbo Build Thread
i'll check it out.... Yeah i figured it had to be something (chassis swap) cause you'd have to make an assload of power to run mid 8's in a 3400lb f-body... that's alot of power for the stock PCM. a chassis change to something lighter makes alot mroe sense....
mustang with an LT1.... interesting....
And yeah, LTx/LSx powered Mustang is a very popular conversion. I think the fox body's are what everyone is running, very light.
A full dizzy/trigger switch is going to be some coin if your starting with a stock intake and PCM. From my knowledge I dont know anyone that has a dizzy/trigger on a stock pcm.
So....
Intake - $1200 ish
Elbow setup - $700 ish
PCM - $2100 ish
Trigger - $250 ish
Distributor - $400 ish
So....
Intake - $1200 ish
PCM - $2100 ish
Trigger - $250 ish
also any build updates?
as well i can pull timing per cylinder1 no better way to make all 8 cylinders happy when spraying 300 through the motor.and folks at CZ are great, imo! I have spent alot of time over there. especially the michigan folks, well except for a couple i can think of, lmmfao!!! apparently i have had some run ins with a particular gutless individual, so i hear. if i had a run in, well he'd know it.
back on track here.... sorry!
