What roller rockers fit under stk valvecovers
Old 01-14-2009, 02:35 PM
1fast432's Avatar
Default What roller rockers fit under stk valvecovers
Would like to go with a true roller rocker,went to order thru jegs and was told the only thing that fits under the stk cover would be a stamped steel stk style rocker. Whats everybody using? THANKS JOHN B
Old 01-14-2009, 02:42 PM
96lt1m6's Avatar
a bunch fit,comp pro mags,crane narrow body etc... generally the hit the webrails on the stock valvecovers. i had the GM/crane Lt4 s on my car no fittment issues and now i have a set of PEP chromoly steel no fittment issues either. pic of the PEP rockers
Old 01-14-2009, 02:52 PM
RamAir95TA's Avatar
Don't let your valve covers dictate which rocker arms you use - that's just silly.
Stock covers will fit most rockers. You will just need to clearance the VC's under the supports (you'll see when you put them on).
Old 01-14-2009, 02:53 PM
ss.slp.ls1's Avatar
After clearancing, you can fit almost any...I like the CC Promagnum 1.6 NSA rr's.
Old 01-14-2009, 03:23 PM
96lt1m6's Avatar
^^^^^wow i feel up close and personal with your valve covers now.....
i hope you are going to smooth those burrs off so they dont fall off into your heads..
Old 01-14-2009, 03:54 PM
ss.slp.ls1's Avatar
Those aren't mine actually, but I clearanced my covers the same way. I use a little file to deburr the cuts. I have not had any clearance issues with my CC 1.6 Promagnum NSA rr's.
Old 01-14-2009, 09:20 PM
1fast432's Avatar
OK thanks guys
Old 01-15-2009, 06:35 PM
8595transam's Avatar
how about the harland sharp 1.6 rr? Anyone have any problems with those?
Quick Reply: What roller rockers fit under stk valvecovers
