which is better
Old Jan 15, 2009 | 07:33 PM
mattgt40's Avatar
Default which is better
which one of these is better for my 95 camaro
1.
http://www.hawksthirdgenparts.com/ca...onnectors.aspx
or
2.
Old Jan 15, 2009 | 07:38 PM
JB_97ws6TA's Avatar
http://www.umiperformance.com/2004?category_id=129
Old Jan 15, 2009 | 07:47 PM
Elliott's94Z's Avatar
Originally Posted by JB_97ws6TA
+2 For the UMI stuff. The 3-point style is nice but if you are limited on funds the 2-points are more then enough. I put the UMI 2-points on and they made a big difference
Old Jan 15, 2009 | 07:49 PM
mattgt40's Avatar
will the 2- be good for for hooking better when i race
Old Jan 15, 2009 | 07:53 PM
Going by your "sig" it looks as if you don't have any suspension work done. If so, I would invest in some Strano/Eibach springs, shocks, Control arms, Panhard bar, torque arm and maybe some sway bars before I would be putting on the SFC.
Old Jan 15, 2009 | 07:58 PM
mattgt40's Avatar
ok ill look into that stuff thanks
Old Jan 15, 2009 | 08:00 PM
SFC would help if you were doing more of track racing..biggest thing I would suggest would be the springs, shocks (Bilsteins) and control arms. Then follow it up with the Panhard Bar and Torque Arm.
Old Jan 15, 2009 | 08:22 PM
mattgt40's Avatar
i would be doin trace racing i rarely race on the street anymore
 Michael S. Palmer
Old Jan 15, 2009 | 08:25 PM
What is Trace racing
Old Jan 15, 2009 | 08:29 PM
mattgt40's Avatar
i meant track racing
Old Jan 16, 2009 | 08:30 AM
JB_97ws6TA's Avatar
I wouldn't put SFC on the back burner, even stock hard launches were putting a lot of stress on the pillars with a t-top so that was the first thing I did with suspension.
Old Jan 16, 2009 | 08:56 AM
Lol..I figured as much. Well if you do more of that you might want to look into a nice set of sway bars along with the springs/shocks.
Old Jan 16, 2009 | 09:23 AM
baylove's Avatar
+1 elliot knows his stuff
Old Jan 16, 2009 | 09:37 AM
darrell hoagland's Avatar
i like the 3 point
Old Jan 16, 2009 | 09:50 AM
Bowtie4life's Avatar
I have the 3pt umi's and I love them. I think differently, I think that subframe connectors should be one of the first things done, I noticed a huge difference in how the car felt after the connectors were on, mainly through turns, you'll think, wow, I never knew the car flexed that much. And I do believe that they helped out my 60' some, I say if you can afford to get the umi 3pts, then do it, if not, then maybe the double diamonds.
Old Jan 16, 2009 | 09:55 AM
The SFC would be good if he does more track racing then 1/4 mile. For better traction though he really needs to get some springs/shocks/control arms first.
Old Jan 16, 2009 | 10:15 AM
porksoda's Avatar
Springs don't help your 1/4 mile one bit. If anything it hurts your times by making it harder for the car to squat down during launch. Shocks are always a good upgrade on these cars as the factory ones suck. As for control arms there is debate on if they help or not. Some people will leave the stock arms in there but put the Moog bushings in if they do not have wheel hop. You can look at my sig and see that I did the things you all are discussing. And lastly as for SFC I think the sooner you throw them on the better. Our cars are unibody adn will flex especially during 1/4 mile or track racing. The sooner you put those on the less it will flex.
Old Jan 16, 2009 | 10:37 AM
UMI Sales's Avatar
Thumbs up Food for Thought!
Hello,
I would recommend working on the suspension first, to get the tires to the ground! and then when you have the figured out! Then pick out the SFC's that's best for your combination.
Thanks Brad
Old Jan 16, 2009 | 10:40 AM
Originally Posted by UMI Sales
Hello,
I would recommend working on the suspension first, to get the tires to the ground! and then when you have the figured out! Pick up the SFC's that's best for your combination.
Thanks Brad
Can't argue with one of the best
Old Jan 16, 2009 | 10:49 AM
popeye954's Avatar
i have the 3 point ones to.
