Gen 1 sbc head conversion
And the LT1 bottom end i have is fresh.If it was a matter of modifying some coolant passages i would like to use the heads that i have.
you have to convert the heads to reverse cooling
the LT1 aftermarket is limited to 23 degree heads and the new trickflow 21 degree heads I heard about
the gen 1 head selection is amazing, plenty of reason to want to convert, 18 degree SB2.2 heads had one guy trapping 137+ mph n/a on an LT1
me personally I'd rather reuse the LT1 intake to cut alot of cost and hassle, plus throw off people when they try to guess what the car has done
CFM(creative flow management) did my conversion. It was $400.
You have to re route the oil return and modify some coolant passages. If you use a standard Gen1 intake like I did they bolt right together. I used the 2 rear coolant ports on the super vic for my coolant bypass.
If you have the heads already, it is WELL worth it. And no it doesnt have to be a HIGH rpm engine, I have stock electronics, opti still in place. My power peaks at 6800.
DOnt waste your money trying to put a stock style intake on these heads. You will choke them. If you are gonna do that port the stockers.
See times in my sig.
The blue plugs were threaded in and the hole above them was angle drilled to be the oil drain.
Re-drill intake, but you wont have to do that
Otherwise just drill and tap a hole in the rear for the coolant tubes
When you say drill and tap for the vent you mean do it the same as the lt1 head.I'm not trying to repeat what you said i'm just trying to be sure.
Do any of the coolant passages need to be blocked off on the gen 1 head?
I really dont recall what else is needed so hopefully someone else chimes in. I do not have the heads here to look at
Pay the money and have it done RIGHT.
You do not have to drill the rear of the heads for the steam/coolant passages. As I stated earlier, use the 2 rear coolant ports on the intake, "T" them together and run it to the radiator.Here is the best pic I have.
[IMG]
[/IMG] Last edited by FASTFATBOY; Jan 23, 2009 at 07:39 PM.
