What's the quickest/cheapest for 12s?
I've seen a 400 hp 389 tq ls1 pull the front wheels with a a4 on a 10 bolt rear end so have a little more faith in your 10 bolt. Keep in mind automatics are not as hard on a rear end as a six speed, unless you have a trans brake.
Even though you said no I would buy an EWP, pull the belt and air filter it should be real close, and under budget. Or get a pulley and leave the belt. Dont forget a good cooldown and ice the intake before you run.
possibly put the catback on? does the lpp/y have cats? if not you may actually be losing power! Get a REAL tune, go to a reputable tuner and have a good STREET tune, not a mail order one on it! If you are dead hooking than suspension won't help you! Cut some wieght!
Hope this helps.
http://www.ringpinion.com/Calc_RPM.aspx
http://www.dynotunenitrous.com/store...?idCategory=46
im done helping.
im done helping.
If it's hittin rev limiter I would get it retuned.
And if it blows up, time for a stroker
