Little pissed off
Old Jan 24, 2009 | 01:54 PM
Bowtie_Aaron's Avatar
the yfz450's have a no start issue.
my friend has the same thing, an 07, and its got the no start issue. the reason is, they have a TPS on the carb, and if the TPS has been off the carb, or the thumb throttle has been off, or the cable been out, or anything they dont want to start. if you jump the TPS it will fire right up.
my friend ran into this one day, and it worked next. then he did an air box, silencer delete, and the cam mod, and it wont fire, but only after jumping the TPS.
this wicked guy sounds stand up. i would be pissed to if there was an issue, i was after i bought mine with 2 blown head gaskets and didnt know it. but i fixed it and beat the snot out of it now.
bad o2's will do some funny stupid things. backfire at idle, backfire under load, no start. run rich. get it changed out and try it then.
aaron
Old Jan 24, 2009 | 02:04 PM
AChotrod's Avatar
Did you jump it or check the batter cables for corrosion yet? Also after my truck sat for months the MAF went bad and caused the truck to run like crap.
Old Jan 24, 2009 | 02:08 PM
Kmaroman's Avatar
it would turn over but not run.
Old Jan 24, 2009 | 02:55 PM
LSWHO's Avatar
Change the damned O2s!!
Old Jan 24, 2009 | 02:59 PM
WhitePhoenix99's Avatar
+1 Says in the for sale add the o2s are bad. . . .
Old Jan 24, 2009 | 03:12 PM
Black94Z28's Avatar
sounds like the original owner is being helpful and doesnt sound shaddy or anything. id be pissed, but you know, it is an older car, stuff does happen and its probably just something small when u do find the answer, so hopefully u find the problem and ur friend can enjoy the car by spring
Old Jan 24, 2009 | 03:30 PM
my o2 was bad on my car, the ground wire was broken. but it ran for a while like that perfectly fine.
i do head gaskets, and now its backfiring. well since i had the battery disconnected it lost everything in the computer. so it had to relearn itself, and it wouldnt with a bad o2.
soldered it up and its been good for the last 11k miles.
aaron
Old Jan 24, 2009 | 04:01 PM
xhk651's Avatar
if the o2s are shot.. you are going to have a world of odd problems...
dont try to fix anything else fist... do those...
Old Jan 24, 2009 | 04:47 PM
lt1performer's Avatar
change the o2s and check all the ground wires. my battery ground looked tear able my car would crank but not stat cleaned all the grounds and started right up.
Old Jan 24, 2009 | 05:03 PM
Formula350's Avatar
Originally Posted by I8ASaleen
You can't really do that to a private seller. If it was a dealership then you have 3 days.
Sure you can. I'm not saying file it under "lemon law".
Old Jan 24, 2009 | 05:07 PM
TasTe_GOOD's Avatar
Originally Posted by wickedformula
yes car did have bad o2's. check engine light would come on while driving. but go out when i turned it off for a while and started it. I don't know where to start because im being completely honest by saying it was running great for me. and the car had a dead battery once we got there. we pushed it off the trailor (he helped!) and into the yard. Same with the quad (dead battery). This was fine by both of us. So the whole story about him getting in it to start it and me leaving was B.S. since the battery was to low. Don't know why we're making things up here, maybe to make me look bad? Really would like to handle this maturely and help eachother out here.
No one is trying to bash you here man, this is what happens when you get only half of the story if you know what I mean. I'm glad you came and am helping to clear things up.
Btw glasspacks straight off the headers do sound badass. My friend did that with his 67 Chevy pickup with a gen 1 350, though I did have to yell "WHAT?" all the time.
Old Jan 24, 2009 | 05:08 PM
  #32
xhk651's Avatar
you have to yell "WHAT" with 1 chambers or bullets or anything like that also... they are all loud as **** dumped..
Old Jan 24, 2009 | 06:10 PM
  #33
Kmaroman's Avatar
I'm not mad wicked since i've cooled down. But i was mad cause iwas so anxious to see the car. I feel bad cause i showed him the car, i have an o2 i can give him.
Old Jan 24, 2009 | 06:36 PM
  #34
Grr's Avatar
Grr
theres no reason to do the O2s and spend $80 on them until you can get the car running. That is just bad advice. They dont do **** till its warmed up anyway and will run if you just unplug them. Also dont just go throwing sensors and **** at it, that too is a waste of $ and not the correct way to do things. Have you pulled the plugs yet? Fix up the injector harness and check spark on all 8 plugs, and verify injectors are firing.
Old Jan 24, 2009 | 06:39 PM
  #35
joelster's Avatar
x2
O2's don't do a damn thing until the car is warmed up and into closed loop mode. Your car doesn't function off of any reading from the O2 for about 2-3 minutes after it runs.
Old Jan 24, 2009 | 06:52 PM
  #36
Formula350's Avatar
Originally Posted by joelster
x2
x3
I was going to comment on that too but forgot.
Old Jan 24, 2009 | 07:18 PM
  #37
Kmaroman's Avatar
Thats what i thought
Old Jan 24, 2009 | 09:10 PM
  #38
wickedformula's Avatar
the only story he got was the full one. whatever happened with it is something new. i had the car running fine so its buggin me too that the car is acting up like this. I would love to see that car up and running and stretchin its legs out on an open highway. I enjoyed it more than anything else having all that power under my right foot. Id like to see someone else enjoy it that much to. like i said, check out the plugs it drove it for a while with the bad o2's so who knows how much crap had gummed up on those plugs from just sittin. As for the quad, i got it running on starter fluid but wont run on its own. thinking its not getting fuel so im in the process of pullin the carb. don't think it was jetting correctly either. but we'll see. just keep me updated really would like to know whats going on with it.
Old Jan 24, 2009 | 09:24 PM
  #39
xhk651's Avatar
i thought the car would start and then run like ****.. .
if not, sorry, i should have read more..
Old Jan 24, 2009 | 09:26 PM
  #40
ebonicrobot's Avatar
Man that sucks. I'm pretty sure you'll figure it out soon. What kind of quad did he trade for it?
