Little pissed off
Reset computer
I suggest putting a timing light on it to check that its still in time. Pull some plugs and check spark, at least 1. This will also let you know that the opti is at least in 1 piece yet
And finally, im assuming you handled all that injector wiring when you were looking at it? Check your fuses and make sure the injectors are still firing. Do that first
got a guy i know maybe doing the work for him
Run some cleaner through it.
