what do you think of these tbs?
I had a ported stocker and it would always stick after a full throttle pass! I screwed around with it for months trying to get it to work right. Now I have a BBK and I am very happy with it! For the few extra bucks I would do the proffesional products looks to be a nice piece for the money!
for the price they are not worth it, for around 175 you can get a proffesional products one and they have a machined air foil, which actually works unlike the ones you buy which are ok, but don't do nearly as much as a foil that is machined it, just buy a proffesional product one and be done!
Moderator
With the 93 stuff, I have never heard of the blades being at a different angle. From my personal experience, the 93 autos use the older detent (Kick down/TV) cable, so the linakge hook ups are specific to the model year. The second issue lies with the IAC, the 93s use the older style "screw in" with a specific connecter whereas 94+ cars use the newer bolt in with a specific connector. EFI connection sells the pigtail needed in the conversion. If the 93 is a six speed and the IAC issue is taken care of, they can use any year TB they wish. The 93 auto guys how ever get in a bind with the detent cable.
With the OEM throttle bodies (aftermarket might be different) the 93s will cause an issue due to the throttle blade angles, they are different from the 94-96 units. The blades rotate less distance to the hard stop so you will not get the same TPS voltage at WOT if you use a 93 unit on a 94-96 engine. You might be able to make a 94-96 unit work on a 93 engine 6 speed car, but just save the potential headach and stick with the proper style unit for your engine. The IAC is different but if you swaped the entire housing/IAC it wouldn't matter as it would bolt up fine.
