what do you think of these tbs?
http://cgi.ebay.com/ebaymotors/_Car-...ayphotohosting
the price is nice, and they offer your 40$ for your stock...idk? should i just pick up a bbk instead?
http://www.professional-products.com/throttleLT1.php
I have one of these, I believe they are under $200. I like it, had it for 3 years and no probs.
I used this guy and got a 54mm one, I have been very happy with it. plus you can order them powder coated red,black or silver.
http://stores.ebay.com/Xtremefi_LT1-...QQftidZ2QQtZkm
id stick with the stock unit bored. flows plenty well unless you'll be going the forced induction route. also has the a better design in the rear unlike all the after market pieces that let air into the plenum after it goes through the IAC. if you notice after market TBs don't have the bleed hole like the stock unit and don't seperate the IAC from the plenum. may lead to some issues later down the road. i had to do some modifications to my BBK unit like sealing off the IAC passage and drilling a bleed hole.
I think the coolant passages are different or something like that.
I will contact him first then. I gotta say though ss.slp.ls1, your a real asset to this forum. Your always there providing good answers to the best of your knowledge w/o any negativity. Hats off to you and Elliot/Shoebox of course!
92&93's will not work on any other year of LT1s other than 92&93's. The throttle likage is different and the throttle blades sit at a different angle than the 94-96 units.
That price isn't too bad, I ported stockers to 52mm for about 4 years. I still got about 60 stock units that I plan on porting some day.
Some ported units are better than others, make sure they install a bearing/bushing of some sort at the throttle shaft ends. Most stockers are worn .008-.010. You will have a better unit if there are bearings/bushings installed. The OEM unit has no bearing/bushing at all, its the steel shaft in the aluminum housing that wears.
for the price they are not worth it, for around 175 you can get a proffesional products one and they have a machined air foil, which actually works unlike the ones you buy which are ok, but don't do nearly as much as a foil that is machined it, just buy a proffesional product one and be done!
