Eecs?
Old Feb 1, 2009 | 07:28 PM
Kmaroman's Avatar
Default Eecs?
I was reading about evaporative emmisions controls last night, was wondering is on a 93 V8 f-body. The book was about f-body but didn't specify if a 93 was different cause i know alot of things changed after 93. It talked about a cannister being hidden in the driverside rear left fender. Anyone tell me more about eecs an its importance. Or can i just yank it out
Old Feb 1, 2009 | 07:52 PM
Formula350's Avatar
Charcoal canister, it vents your tank of excess pressure and feeds it into your engine for burning. No real reason to remove it unless you're running an aftermarket tank or want a totally tidy engine bay. I'd leave it.
Old Feb 1, 2009 | 08:45 PM
shbox's Avatar
If you remove it, you will have to find a way to deal with the fumes.
Old Feb 1, 2009 | 08:50 PM
Kmaroman's Avatar
I don't think its working because when i unscrew the cap on the gas tank. I smell alot of fumes an there alot of pressure that realises when i take it off.
Old Feb 1, 2009 | 08:54 PM
kinglt-1's Avatar
I thought it's normal to smell gas when the gas cap is off? If you smell gas when the cap is on, then there's a problem with the evap system.
Old Feb 1, 2009 | 08:58 PM
RamAir95TA's Avatar
That is perfectly normal.
Old Feb 1, 2009 | 09:06 PM
Kmaroman's Avatar
Oh from what i read eecs helped prevent those high pressures so i assumed different
Old Feb 1, 2009 | 09:20 PM
RamAir95TA's Avatar
It does, but you don't drive around with your gas cap off. It's gotta vent somewhere.
