Cam help?
Old Feb 4, 2009 | 10:02 PM
chrisLT1's Avatar
Default Cam help?
need to know what size cam i should use for my new LT1
Old Feb 4, 2009 | 10:04 PM
nik1703's Avatar
depends what kind of results you want to get and how much you want to spend. If you're sticking with the stock head, then check this out
https://ls1tech.com/forums/lt1-lt4-m...wap-guide.html
Old Feb 4, 2009 | 10:19 PM
chrisLT1's Avatar
hell yeah thanks dude
Old Feb 5, 2009 | 12:52 AM
robsquikz28's Avatar
that will do it for ya man if you want to hear the cam sounds just pull a search and you can find all sounds of differ cams on here
Old Feb 5, 2009 | 09:22 AM
Elliott's94Z's Avatar
Really depends on what your main goal is with the car. Will you need to pass emissions? Are you going to run it with the stock heads? Is it going to be a daily driver or mainly a drag car? And do you have the supporting mods to go along with a cam??? I don't see anything listed in your **sig** Post some more info up and we can help steer you towards what camshaft will work best for your application.
Elliott
Old Feb 5, 2009 | 07:27 PM
chrisLT1's Avatar
ok well i will have the stock heads and they will have work done and better springs i want a great sound but i dont wanna risk the nice drive or usable power what else do you wanna know
Old Feb 5, 2009 | 08:07 PM
I need to know exactly what I asked in my first post What mods do you have done already, daily driver or a strip car etc etc
Old Feb 5, 2009 | 11:03 PM
chrisLT1's Avatar
so far i have LT headers to X-pipe to 3in bullets dumped at rear end 2800 TCI stall .30 over forged pistons head work better springs and not sure if im gonna go with RR's or not its not gonna be a true drag car yet but thats kinda what im going for but right now its a daily driver
Old Feb 6, 2009 | 01:04 AM
See if anything sparks an interest on this site http://www.elliottsportworks.com/lt1.html
I would put some 1.6 RR's on. Worth an extra 10@the rear
Old Feb 6, 2009 | 12:55 PM
chrisLT1's Avatar
ok with the 223/230 .565 is that a choppy idle what is considered mild i have really loud high flow exhaust so should be able to hear even the smallest cam
Old Feb 6, 2009 | 01:18 PM
That's pretty much the exact cam I went with. It would be a great Daily driver and not be too bad for 1/4. If you are looking to get a little more sound out of that camshaft I would rec changing the lsa to a 110 or 109. The 112lsa will sound good but noting too radical. I went with a 109 and it sounds pretty sick. Got a nice lope to it.
Old Feb 6, 2009 | 01:24 PM
ss.slp.ls1's Avatar
Same here, I have a CC503, very similar specs. I have a y-pipe and the SLP 2OTL exhaust, you can hear the lope, it's nothing radical though.
