Comp custom grind
Old Feb 5, 2009 | 04:53 PM
clwz28's Avatar
Default Comp custom grind
I found a extreme roller custom grind with these specs 218 int.,228ex. 503 lift int./510 ex.,but has 110 sep(270/278 adv.).The cam is a cross between a 502 and a503 cam,I like it except for the lobe sep.,what do you guys think,will hurt my over rev and be to rough of a idle for my dd driver?
Old Feb 5, 2009 | 04:58 PM
StealthFormula's Avatar
If you need to pass emissions that probaly wont, just in case that may be a concern. Don't know all the specs of the cam but a 110lsa should be fine for DDing and should sound pretty decent too.
Old Feb 5, 2009 | 05:01 PM
ss.slp.ls1's Avatar
I'd run it, I don't see anything wrong with those specs.
Old Feb 5, 2009 | 08:30 PM
RamAir95TA's Avatar
You need to make sure the cam is LT1-specific. Typical SBC cams will not work.
Old Feb 5, 2009 | 08:47 PM
clwz28's Avatar
Its a short pin oem roller.
Old Feb 5, 2009 | 08:48 PM
96lt1m6's Avatar
'87-'97 roller cams have a step nose and the thing to watch for is the dowel pin. you would be good to go...
you can get a longer pin if needed.
Old Feb 6, 2009 | 07:07 AM
DAVE00's Avatar
Is that lift on a 1.5 or 1.6 as it seems pretty small?
Old Feb 6, 2009 | 07:16 AM
ss.slp.ls1's Avatar
Probably with 1.5 ratios rockers.
Just so you know, the lift on a CC503 is .502/.510.
