help me choose some gaskets!
Is this a good set?
Also, I was wondering if there is anything else anyone suggests replacing. Maybe valve stem seals?
Heres an untuned vid to get you pumped - http://www.youtube.com/watch?v=9XI76...e=channel_page
Good luck!
Manifold gasket set + Timing cover set and a pair of VC gaskets should pretty much cover it.
(make sure the timing set comes with Waterpump gaskets; if not, get those too)
Felpro makes good stuff.
If you pull the heads for some reason, you'll also need head and exhaust manifold gaskets.
Don't forget to get an updated tune. (mailorder at a minimum)
