piston help
Old Feb 19, 2009 | 10:25 PM
screming_z28_95's Avatar
Default piston help
aight so im puttin new pistons in the car but i need help finding some i wanna go forged and i wanna keep the cost under 400 is this posibile and if so what kind and were kidn i find them?
Old Feb 19, 2009 | 10:32 PM
ss.slp.ls1's Avatar
I don't think you can find a decent set of forged aluminum 4.030" pistons for under 400 new. I'd check the classifieds.
Old Feb 20, 2009 | 05:29 AM
RamAir95TA's Avatar
You can find cheap forged pistons for around $400 from a few vendors, but where are you going to get the money for the machine work, bearings, assembly, etc.?
Old Feb 20, 2009 | 06:43 AM
96capricemgr's Avatar
Look at the Mahle PowerPak, once you consider the included rings, pins, coatings they are a very good value.
IF you find something that actually fits your current wishes it will probably be a thick parasitic ringpack that causes excessive bore wear and the piston will likely be heavier adding stress to the rod bolts, probably not the step forward you were hoping for.
Old Feb 20, 2009 | 07:55 AM
myltwon's Avatar
check ebay
Old Feb 20, 2009 | 12:53 PM
the bottom end crank rods etc. all aready ared forged the im just changing the pison from a dish to a dome or flattop piston for more compresion
Old Feb 20, 2009 | 12:55 PM
ss.slp.ls1's Avatar
You can get a nice set of JE forged alum pistons in any style you want for a ~$700 on Summit, but that's more than you were looking to spend.
Old Feb 20, 2009 | 01:07 PM
moehorsepower's Avatar
First off, do you really need forged pistons? are you planning to spray? Look at the 427,,Hyper pistons.....
Old Feb 20, 2009 | 09:25 PM
myltwon's Avatar
with boost I wouldn't risk hyper pistons, n/a and moderate n2o I'd be a little more willing
Old Feb 21, 2009 | 01:10 PM
i am spraying it thats y i need the forged
