Do I need a tune?
Old Feb 23, 2009 | 06:36 PM
meangreenchevy's Avatar
Default Do I need a tune?
About to put on a set of pacesetter long tubes and there off road y pipe... the headers have the egr/air fittings... do i NEED to get it tuned for just the headers?
Old Feb 23, 2009 | 06:37 PM
$O$OE's Avatar
i dont have my car tuned
Old Feb 23, 2009 | 06:40 PM
Elliott's94Z's Avatar
Nope...although it would benefit your car if you did. A mail order would be all you would need at this point if you do.
Old Feb 23, 2009 | 06:50 PM
SHDY 5.7's Avatar
It is possible for the new exhaust to cause the knock sensor to pull timing.
Id get a mail order tune just to be safe. That and u can pick up a few more ponies....
Old Feb 23, 2009 | 06:55 PM
Formula350's Avatar
I wouldn't bother with one till you do something big like a cam or H/C package. If you get knock retard you can slap in the LT4 knock module. However if you don't have any plans to do anything more radical then you currently have, I'd go for it!
But no, you don't need one right now. The only thing you'd need it tuned for is injectors, otherwise you can harm your engine in the long run.
Old Feb 23, 2009 | 07:05 PM
BigBadWhitey's Avatar
Save a tune untill you do more to the car. I only have pacesetter LT's with air/egr and the matching ypipe, all i needed was rear o2 sims and she runs just dandy. I found without the o2 sims it would run a bit off....in 6th gear it hummed along really strangly, like it was gutted. With the o2 sims it runs just as smooth as stock.
Old Feb 23, 2009 | 07:35 PM
Formula350's Avatar
Which is odd since the rear O2s don't do anything accept give the computer something to compare against to make sure the cat/s is/are working. Close to what the fronts are reading, it'll throw a code to replace the cat. The sim is just there to keep the CEL/SES off.
Old Feb 23, 2009 | 08:21 PM
Camaro_94's Avatar
It would help, but you dont have to.
Old Feb 24, 2009 | 10:25 AM
forgot to mention its a 97 lt1 that is obd2... did some reading and ppl are saying that if i dont get it tuned its goint to run like crap
Old Feb 24, 2009 | 11:02 AM
Then get a tune You can't go wrong with one.
Old Feb 24, 2009 | 12:24 PM
anyone else?
Old Feb 24, 2009 | 12:44 PM
96lt1m6's Avatar
the tune was worth the NEW smooth idle,raised rev limiter and the added timing advance,the fan control etc.. i was consistantly running 14.2s spinning in the heat with ugly DA 3000'+ after the tune and similar conditions i was running 13.8 next was drag radials bogg,clutch slippage,13.35 then the clutch EXPLODED aka TANERIZED
Old Feb 24, 2009 | 01:13 PM
SoxXpupPeT's Avatar
no you do not need a tune. it is highly recommended tho
Old Feb 24, 2009 | 02:09 PM
hbgben's Avatar
Once yo install the hearders, after a while you will notice a few slight driveablility issues that could use attention. I noticed that with my 97. If you have the funds, it doesn't hurt to get it tuned, otherwise wait a while till you acquire more mods.
Old Feb 24, 2009 | 08:12 PM
V10GTS's Avatar
if your cars a mass air car then probably not.
