LT1 383 Build
Machine work adds up fast and an internal balance + turning can quickly add
to up a cost that will make you wish you ordered a forged aftermarket crank.
I recently put 5 slugs into a stock crank and had it turned .010" to replace a broken crank in a 355.
If it's known it was going to cost that much I'd have put the money towards an upgrade instead.
I did that in the beginning with a VERY small cam and made about 380 to the wheels. Used the stock crank, some old style steel Chevy rods, Probe forged pistons.
Take it down, have the block checked for taper wear. If its ok, Hone it with torque plates. Replace the rings, rod, cam and main bearings, new oil pump, ARP rod bolts and put it back together.
If the block needs boring, bore it and put a set of $450 speed pro forged pistons in it.
SLap the head/cam package you want on it, have ALOT more fun with that than with a stock headed 383.
Thats exactly what id do, hell our stock rods are strong its our pistons that are junk. Id do exactly what you did, its the best way to go. And its simple, your going to spend thousands of dollers to wait for speed.
Do a reliable budget setup and have fun with it, trust me a big cube motor with stock heads isnt any fun at all.
Build a motor with YOUR MEANS, not your DREAMs and you will have alot more fun with it.
Head n Cam with a fresh bottom end and forged pistoned.
Heads are the key to power!
Its like a 460cube ford, or a big block caddy sure its got the cubes but they head flow just isnt there.
Try to work out a deal with the dynotuner, see if they'll let you have the base tune ahead of time.
(the one they'd have to build for you to get started on dyno day anyhow)
Some tuners are ok with that if you pay up front ... some aren't.
I was pushing the limits of SVO reds with my 350 and a smaller cam.
I like racetronix's (Lucas) flow-matched injectors, 37 or 42#.
The 255 will bve fine, but 30# are going to be a little small.
I like racetronix's (Lucas) flow-matched injectors, 36 or 42#.
Went on the racetronix site, lloyd reccomends 37#. any part numbers?
Being "bigger" isn't a problem. It just gives you room to grow.
http://www.racetronix.com/01D114x.html - 37# (+/- 4%)
http://www.racetronix.com/621031FM.html - 42# FlowMatched (within 1%)
Thanks. I've been soaking up the info the forums have about these builds. I'm not looking for a dragstrip monster, just a nicely built motor for my DD. Everyone's happy with this setup and it's proven.
The stock pump will have trouble keeping up with fuel demands at high RPM, dropping pressure, which will leave you running lean.
If you want to hold off on the pump, keep RPMs low enough that FP doesn't drop off.
(a gauge can be screwed into the fuel rail to test)
If your budget is running thin (and they generally do at this point of the build), check the for sale
section for used parts from people with good reputations. I'd rather see a used part in there than
a part that can't do the job.
I eliminated mine after seeing that even the turbo guys run without them.
