LT1 383 Build
have you atleast priced local shops for head porting? I've seen some go for 300-400 for a decent port job, get some matching springs, then get a custom cam for $300 from Lloyd or look for a decent off the shelf cam used
I did that in the beginning with a VERY small cam and made about 380 to the wheels. Used the stock crank, some old style steel Chevy rods, Probe forged pistons.
Take it down, have the block checked for taper wear. If its ok, Hone it with torque plates. Replace the rings, rod, cam and main bearings, new oil pump, ARP rod bolts and put it back together.
If the block needs boring, bore it and put a set of $450 speed pro forged pistons in it.
SLap the head/cam package you want on it, have ALOT more fun with that than with a stock headed 383.
Doing the same thing to a LT1 and having the machine shop assemble it would only be a couple hundred more.
Not refreshing a stock motor. In refreshing a stock motor you have to buy less so the budget can be smaller.
And even if you do want to build the bottom end I wouldnt put all you money towards upping the cubes. That will do very little for power, I would put all my money to the heads, as they determine how much power the motor can make.
Have you thought about cheap forged pistons, arp hardware and stock crank and rods. It should be good for 450rwhp and would leave much more loot to spend on the top end?
I just see no reason to build a bigger motor that will always be held back by the heads??
Go with an aftermarket good set of rings and a nice forged piston.
And what do you mean "spendy comp roller rockers"? It's just another recommended cost when upgrading. IMO, NOT going with new roller rockers on LE heads is lunacy.
Oh yea I'm definitely doing it, don't get me wrong. I'm also just going to go ahead and have the intake ported, if it's worth doing for a daily driver? The throttle body and injectors are just going to have to wait a bit.
Good to know I'm not the only one caught up in a bind. I'm going ahead with the freshening up of the bottom end with some good forged pistons. Just hoping the crank and rods are good. but if i can get out with just spending 3,000 to 3,500 bucks on the rebuilt bottom end and top end assembled I'd be happy, as I was almost about to waste nearly the same amount on a stock headed 383. Lol if it weren't for these guys here, I woulda went with the 383 build as it was the easier route, but less satifaction.
